RE: Invites not appearing as tentative in calendar - Oulook 2003
  • Thread starter Maurício Paiva
  • Start date Views 1,508
Maurício Paiva
Hi techieBird!
I have an user who always appears as tentative even if appointment is
accepted/declined. Also we cannot see her availability on outlook before
sending the appointment on a approprietated time.
Now I realize user changed (under outlook settings) to all msgs arrived
being moved to a pst file instead of mailbox
I didnt call user again to not give her false hope in case of no success but
do you think if she start using mailbox again as primary recipe this will
work?
Txs,
Mau
"TechieBird" escreveu:
> Hi there
> Outlook uses a piece of code called the sniffer to add invites as tentative
> items to your Calendar.
> Most likely reasons for it not to fire are
> 1) the setting for this behaviour may be switched off: Tools > Options
> (Preferences) > Email Options > Tracking Options > Process requests and
> responses on arrival
> 2) the sniffer only works on the Inbox so if the item gets moved by a rule
> then it may not get 'sniffed'. In this case, figure out which rules may
> apply on invites and add the exception "except if it is a meeting invitation
> or update" on the last page of the rules wizard.
> See http://bwain-dump.blogspot.com/2007/06/outlook-inbox-sniffer.html for
> deeper explanation and troubleshooting.
> > TechieBird
yes, if she uses the mailbox as her default delivery location, it will work
correctly.
"Maurício Paiva" <MaurcioPaiva> wrote in message
news:B584A60D-10D3-4E6E-A831-584877BB4678@microsoft.com...
> Hi techieBird!
> but
> work?
> Txs,
> Mau
> > Hi there
> > tentative
> > rule
> > invitation
>> > > TechieBird
L
Leonid S. Knyshov // SBS Expert
On 3/12/2010 1:57 PM, Maurício Paiva wrote:
> Hi techieBird!
> work?
> Txs,
> Mau
You can further control what users can do with delivery options through
group policy. Re-routing to PST is a terrible idea and the user probably
does not realize that the messages are no longer backed up.
Leonid S. Knyshov
Try Exchange Online http://bit.ly/free-exchange-trial
