Reader pane problem
N
nobody
The reader pane in my OE6 has a problem. As I read and scroll down
usually using my Intellimouse scroll wheel button the screen jumps back to
the top. Can this be fixed?
regards,
"nobody"
N
nobody
update - The problem also exists even if I drag the reader pane scroll bar
down. I then start reading and the page jumps back to the top?
"Nobody"
"nobody" <nobody@nowhere.com> wrote in message
news:%23meWut4wKHA.5940@TK2MSFTNGP02.phx.gbl...
> regards,
> "nobody"
Bruce Hagen
Does this happen when reading e-mail, news, or both. If news only, it is
related to when OE is set to poll for new messages. A known bug that will
never be fixed. If it happens for mail as well, it is either the mouse, or
a damaged identity.
You may have a damaged identity especially if it is the default Main
Identity. File | Identity | Add New Identity. Create a new one and test
it. If all is well, you can import your messages and Address Book from the
old identity and delete it.
Note: Do not use the word Main in the name of the new identity.
How to Create and Use Identities in Outlook Express
http://support.microsoft.com/kb/209169
An Outlook Express basic repair kit:
http://www.microsoft.com/windows/IE/community/columns/oerepair.mspx#EHH
Bruce Hagen
MS-MVP [Mail]
Imperial Beach, CA
> to the top. Can this be fixed?
> regards,
> "nobody"
P
PA Bear [MS MVP]
From your post's headers: Outlook Express 6.00.2900.5512
Can you get that WinXP SP3 computer fully patched at Windows Update before
worrying about this odd cursor behavior?
> regards,
> "nobody"
V
VanguardLH
This is a behavior of OE when it polls for new e-mails and/or newsgroup
posts. When OE does a poll, you lose your current position inside the item
that you are reading. It's a nuisance. It's an even greater nuisance if
you set your polling exceedingly short which is considered abusive. Set the
poll interval in OE to 10 minutes, or longer (5 minutes at a pushy minimum).
If you set the poll interval at 1 minute then every minute OE is going to do
a mail poll (and perhaps step atop a poll already in progress) and you're
going to see the effect that you reported.
V
VanguardLH
Wonder what PA Bear thinks should be the latest version of OE6 on Windows XP
Pro with service pack 3? I also have 6.00.2900.5512, I have SP-3, I have
all the available updates through the WU site, and the WU site offers me no
more updates to OE6. Besides, the security updates available since 2006
won't address *program* changes to its behavior to rectify the change in
current position within an item when OE polls the email/newsgroup servers.
N
nobody
"VanguardLH" <V@nguard.LH> wrote in message
news:hnjppl$7pf$1@news.albasani.net...
>> to
> item
> the
> minimum).
> do
Many thanks,
"nobody"
