Userform
Bre-x
I have create a user form data connect to an ms access db
My ListBox1 shows email address.
I would like to double click on a record so that the email value
will be paste on my New Email's To field.
Thank you all
Bre-x
Michael Bauer
What's your question?
Best regards
Michael Bauer
Am Mon, 15 Mar 2010 15:25:50 -0600 schrieb Bre-x:
> Thank you all
> Bre-x
Bre-x
I need the VBA code to put on my listbox double click event.
So that the address will be paste on the "To" box on the new email form.
thnks
"Michael Bauer " <mb@mvps.org> wrote in message
news:144995k5ko7w3$.1l0q2jn2agb62$.dlg@40tude.net...
> > Best regards
> Michael Bauer
>> Thank you all
>> Bre-x
JP
In your listbox double click event:
Call CreateEmail(ListBox1.Value)
Then somewhere else in your form class:
Function CreateEmail(emailAddr As String)
Dim Msg As Outlook.MailItem
Set Msg = Application.CreateItem(olMailItem)
Msg.To = emailAddr
End Function
Customize as needed.
--JP
> thnks
> "Michael Bauer " <m...@mvps.org> wrote in messagenews:144995k5ko7w3$.1l0q2jn2agb62$.dlg@40tude.net...
> > > > Best regards
> > Michael Bauer
> >> Thank you all
> >> Bre-x-
Bre-x
Hi JP
Thanks for anwering my post.
Unfortunately, It does work. The value of the listbox is not paste into the
"To" field.
"JP" <jp2112@earthlink.net> wrote in message
news:8257a026-c2f4-41da-b90a-ab53a345d6b8@l40g2000pro.googlegroups.com...
Msg.To = emailAddr
End Function
--JP
> thnks
> > > > Best regards
> > Michael Bauer
> >> Thank you all
> >> Bre-x-
JP
I assume you meant it does *not* work.
We need more information to diagnose.
Where are you putting this code?
Can you be more specific than "it doesn't work?"
Is the code in the proper place?
Is there an error? If so, what is the error code and text of the error
message?
--JP
On Mar 16, 11:19 am, "Bre-x" <cholot...@hotmail.com> wrote:
> Hi JP
> "To" field.
> "JP" <jp2...@earthlink.net> wrote in message
>   Msg.To = emailAddr
> End Function
> --JP
