1. Here's a thread that needs an answer: Scroll Crash
Changing from POP to IMAP
Discussion in 'Using Outlook' started by rfoszcz, Mar 22, 2010.
  1. rfoszcz
    rfoszcz
    Guest
    I originally set up a GoDaddy hosted email account as POP. In the past
    year I've created many, many folders under the PERSONAL folder. I now
    want to change the GoDaddy account to an IMAP based account. I removed
    the POP account and created an IMAP account but the INBOX for the IMAP
    account shows up a separate account rather than the INBOX under the
    PERSONAL folder.
    Is there a way to "move" the IMAP account under the PERSONAL folder so
    that the INBOX in PERSONAL corresponds to the newly configured IMAP
    account?
    Any help or suggestions is appreciated...
    rfoszcz
  2. Leonid S. Knyshov // SBS Expert
    Guest
    > PERSONAL folder.
    > account?
    Your question really is:
    "I used to have a Godaddy POP3 account setup in my Outlook (unknown
    version) and now I am switching to IMAP4 account at Godaddy but Outlook
    created a separate set of folders for the IMAP account. Can I store
    those messages in my previous PST."
    The answer is No. IMAP4 accounts are different from POP3 in that they
    support their own folders.
    You can configure a rule to automatically copy your messages, but there
    is little point in it. What makes sense is to configure Outlook to open
    inside the IMAP Inbox folder by default.
    For Outlook 2007, click on Tools -> Options -> Other -> Advanced Options
    -> Startup in this folder
    Using IMAP4 is a good decision. You'll enjoy resiliency in having your
    mail available from anywhere. Your ISP will experience lower server load
    as compared to POP3.
    If you remove the top "Personal Folders" PST from Manage data files,
    Outlook will recreate it anyway, so there is no way to get rid of it.
    Leonid S. Knyshov
    Try Exchange Online http://bit.ly/free-exchange-trial
  3. Diane Poremsky
    No, you need the personal folders for calendar and contacts, which are not
    supported by imap. If you want the imap inbox to be you start folder, go to
    Tools, Options, other tab, Advanced button - top option. See
    http://www.slipstick.com/tutorials/startfolder/startfolder.htm if you need
    more help with this option.
    "rfoszcz" <rfoszcz.5edf65b@outlookbanter.com> wrote in message
    news:rfoszcz.5edf65b@outlookbanter.com...
    > PERSONAL folder.
    > account?
    > > rfoszcz
Loading...
Share This Page
