Macro or predefined setting to export from Outlook?
  • Thread starter Pengyou
  • Start date Views 673
P
Pengyou
#1
I use Outlook at my addressbook and email reading but have to sync with
several portable devices as well as some online addressbooks. Those that do
not sync directly can be satisfied with an appropriately formatted csv file.
Is there any way I can "save" a setting to make a csv file, or create a macro
to make these files automatically?
Michael Bauer
#2
See if File->Import/Export does it. There you can choose Export to File,
colon delimited.
Of course, writing your own macro would also be possible.
Best regards
Michael Bauer
Category Manager -
SAM - The Sending Account Manager:
<http://www.vboffice.net/product.html?lang=en>
Am Wed, 7 Apr 2010 08:02:01 -0700 schrieb Pengyou:
do
file.
macro
