Priv1.EDB to PST
jarobs flexan
You have a chance to migrate your corrupt priv1.edb file to PST file and read and maintain all the existing user accounts in MS Outlook. For these action choose Enstella EDB to PST migration toolkit and effectively migrate priv1.edb to pst mailbox. Get the complete story about Enstella Exchange Recovery from http://www.enstella.com
Jarobs...
Branda wrote:
Is it possible to restore from just priv1.edb etc. files?
24-Sep-07
I had a dead SBS 2003 server. Had to rebuild from scratch and used the same
server and domain name. Basically to cut a long story short, I only have the
raw files and logs. Priv1.edb, priv1.stm, pub1.edb etc.
Is there anyway I can restore to the new setup ?
Would appreciate your help.
Brandan
Previous Posts In This Thread:
On Monday, September 24, 2007 1:00 PM
Brandan
On Monday, September 24, 2007 1:07 PM
John Oliver, Jr. [MVP] wrote:
Yes, since you did use the same Server name you should be able to follow these
these steps to mount your databases:
1. Stop your Information Store service.
2. Copy the contents of the MDBDATA folder to a temp location.
3. In ESM, go to your Mailbox Storage Group properties under Database tab
and make sure "this database can be overwritten by restore" is checked.
4. Copy the old priv1.edb, .stm, etc. to the MDBDATA folder.
5. Now right click in ESM and mount Store.
6. Now right click on the mailbox store and select Run Cleanup Agent. This
will mark all the mailboxes with Red X's.
7. Right click each mailbox and reconnect to user accounts.
John Oliver, Jr
MCSE, MCT, CCNA
Exchange MVP 2007
Microsoft Certified Partner
"Brandan" <Brandan> wrote in message
news:6AFAC7A2-2DCC-4065-B3A3-A6E5176033CE@microsoft.com...
On Monday, September 24, 2007 1:34 PM
Branda wrote:
Thanks for your help John.Do I copy the log files as well?
Do I copy the log files as well? Everything in MDBDATA ?
Brandan
"John Oliver, Jr. [MVP]" wrote:
On Monday, September 24, 2007 1:48 PM
No need to copy log files just the .edb and .stm files.
John Oliver, Jr
MCSE, MCT, CCNA
Exchange MVP 2007
On Monday, September 24, 2007 4:02 PM
Branda wrote:
OK, looking good so far.
OK, looking good so far. Except, when I try to reconnect to them to there
users accounts, I get...
'An object (Users or Object) with the following name cannot be
found:"username". Check the selected object types and locations for the
accuracy and ensure that you have typed the object name correctly, or remove
this object from the selection.#
The user accounts do exist. under users in Server Management.
Brandan
On Monday, September 24, 2007 4:56 PM
If the user new user accounts already had mailboxes created for them then you
you will need to delete the mailboxes through ADUC before reconnecting them.
John Oliver, Jr
MCSE, MCT, CCNA
Exchange MVP 2007
news:C69CD458-E20A-4941-918A-3C8DFC3338BD@microsoft.com...
On Monday, September 24, 2007 5:10 PM
Branda wrote:
Yes, that worked. Fantastic!
Thank you John, I really didn't think we would be able to do it from just
the files. Now I need to install a decent backup !
Thank you again, hope this thread helps another !
Brandan
On Wednesday, April 14, 2010 1:00 AM
jarobs flexan wrote:
Priv1.EDB to PST
Jarobs...
Submitted via EggHeadCafe - Software Developer Portal of Choice
BizTalk Custom Pipeline for Splitting Messages
http://www.eggheadcafe.com/tutorial...6-241d5e325f42/biztalk-custom-pipeline-f.aspx
A deadhead spammer from egghead leeching unto a 3 yr old post
Peter
Please Reply to Newsgroup for the benefit of others
Requests for assistance by email can not and will not be acknowledged.
<jarobs flexan> wrote in message news:20104141050angel.techworld@hotmail.com...
> Jarobs...
> 24-Sep-07
> Brandan
> Brandan
> > John Oliver, Jr
> MCSE, MCT, CCNA
> Exchange MVP 2007
> Brandan
> > John Oliver, Jr
> MCSE, MCT, CCNA
> Exchange MVP 2007
> Thanks
> Brandan
> > John Oliver, Jr
> MCSE, MCT, CCNA
> Exchange MVP 2007
> Brandan
> Priv1.EDB to PST
> mailbox.
> Jarobs...
Yes you can easily open Exchange Server EDB files with Microsoft Outlook, use EDB to PST converter software for performing this task. Tool is available free of cost. just download now and use Exchange mailboxes with MS Outlook.
B Exchange 2003 EDB corrupt Exchange Server Administration 6
B Old attachments do not open after Exchange 2007 edb recovery. Exchange Server Administration 3
V Recover exchange 2010 edb Exchange Server Administration 2
P Recommendation for PST repair program Using Outlook 1
P Outlook 365 Bad experience with KernelAPPS PST Repair program Using Outlook 0
HarvMan Importing PST into IMAP account Using Outlook 12
K Moved pst to new computer, now Gmail not coming into Outlook Using Outlook 7
W Outlook 365 File access denied attempting to import .pst Using Outlook 6
S Import PST to Office 365 Using Outlook 1
J Recover server side rules from OST/PST without access to the server Using Outlook 2
HarvMan Exporting IMAP OST file to PST Using Outlook 5
J What are .PST.db and .PST.db.journal Files? Using Outlook 2
Abraham Outlook 2013 Lost my folders when moving from PST to IMAP Using Outlook 11
L Article on merging pst file Using Outlook 1
J Outlook 2019 i dont want to buy the snake oil ost to pst programs Using Outlook 1
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
K Export Folder to PST Outlook VBA and Custom Forms 2
HarvMan Outlook 365 PST Report Using Outlook 1
P PST file is getting huge under POP 3 Using Outlook 2
J Export Zimbra to Outlook PST Using Outlook.com accounts in Outlook 1
S What's in a PST file? Using Outlook 1
N pst files are recreating automaticaly and cannot be deleted Using Outlook 5
