Detecting if attachement is embedded or not
Russ Green
I've seen lots of discussion on this but no answers.
I have an addin (VB.NET and VSTO) that strips attachements from emails as
they are sent. Trouble is, I don't want to strip attachement (usually
images) that are within the body of the message. I quite often paste images
from the clipboard into my HTML messages and these need to be retained.
So when looping through the attachments in a message how can you robustly
check if the attachment is embedded or not?
Based on other articles I've seen I thought something like this might work
by actually oAttachments.Type doesn't seem to be any different between an
attached XLS file and an embedded JPG file.
Private Function HasNonEmbeddedAttachements() As Boolean
Dim retval As Boolean = False
Dim oAttachment As Outlook.Attachment
If m_olMailItem.Attachments.Count = 0 Then
retval = False
For Each oAttachment In m_olMailItem.Attachments
If oAttachment.Type = Outlook.OlAttachmentType.olByValue
Then
retval = False
retval = True
Exit For
Return retval
End Function
May have found a simple way.....seems to work at least but will test for a
while first
retval = False
If m_olMailItem.HTMLBody.ToLower.Contains("cid:" &
oAttachment.FileName) = True Then
retval = False
retval = True
Exit For
Return retval
End Function
E Issue with detecting changes in a folder. Outlook 2003. Outlook VBA and Custom Forms 3
Q Re: Detecting whether a toolbar is and should be shown Outlook VBA and Custom Forms 5
J Customize Attachement Security Warning Using Outlook 1
R compare folder contents to e-mail attachement Using Outlook 1
J How to open PDF attachement upon arrivel new mail Using Outlook 20
A PDF Attachement Errors with Outlook 2010 Using Outlook 7
S Save Attachement from outlook Using Outlook 2
G Converting Attachement into Link. Outlook VBA and Custom Forms 1
H Outlook 365 issue getting details from embedded files, crashing routine Outlook VBA and Custom Forms 0
K Embedded photos no longer open with Photos or Photo Viewer Using Outlook 7
O Non-standard fonts - are they embedded? Using Outlook 2
S Email Format With Embedded Images and Tables Change Using Outlook 2
Q Why can't I copy image with embedded hyperlink from email to Word Using Outlook 0
E Embedded form in email Using Outlook 1
R Deleting Attachments(embedded) in Outlook 2013 Using Outlook 10
R How can I retain embedded object with voting button reply? Using Outlook 5
R Outlook 2007 not displaying embedded images in emails Using Outlook 1
N Outlook refuses to show embedded images on Citrix Windows 2008 R2 Using Outlook 29
D Use Outlook 2003 embedded imaged cannot print from the mail preview list Using Outlook 4
M Save embedded image in native format Using Outlook 6
S Embedded links Using Outlook 1
V Can't click on embedded link in Outlook e-mails--error message "not allowed" Using Outlook 6
K loop through distribution group (and potentially, embedded DGs) by Outlook VBA and Custom Forms 1
T Saving Embedded Images in Outlook 2007 Outlook VBA and Custom Forms 3
