Outlook Rules Case Sensitive
Ashwin
Are Outlook 2007 Rules case sensitive?
Can you help me to know all the Outlook 2007 Rule that are case sensitive?
Thanks in advance..
Ashwin K
"Ashwin" <msnews08@nospam.nospam> wrote in message
news:6F34A0D5-3D11-463D-B559-4E97680BDA27@microsoft.com...
Didn't you already ask this? The answer then, as now, is no.
Outlook rules are indeed case sensitive. I don't know when 'they' changed it. But all of the sudden the rules of one of my accounts didn't work anymore. I tried cleanrules - but to no avail. Only when I bought a new computer and had to configure Outlook 2007 there, I found out - by experimenting with the rules - that the rules are indeed case sensitive (like when I use BabuNiki instead of babuniki, the 'babuniki' rule doesn't work).
BabuNiki
How does your rule read?
The rules are in German. I hope you will get it when I translate: Mails with BabuNiki or babuniki in the header, move to directory A, and a copy of it move to directory B. Apply no other rules. This rule worked fine for years. But then, from one day to the other, the mails refused to move. Only when I added the upper-case name to the rule, it worked again. (I assume that this case distinction was part of an update by MicroSoft.)
BabuNiki
As you say, it would appear *SOME* rules are case sensitive and it appears to be in contect. Take the email address below as an example:
InsideLitigation <admin@enews.sbmedianews.com>
Now, if I select "from people or public group" it will take inside litigation, INSIDELITIGATION or InsideLitigation. However, if you pick "with specific words in the senders address, sometimes it doesn't care and some times it does. If you use "with specific words in the message header" it is always case sensitive.
Very odd programming behavior, but I'm just reporting it, not writing the code :)
---Mike
Wayne Outlook locks up when opening "Manage Rules & Alerts" Using Outlook 7
D Outlook Rules Using Outlook 1
Gunny NFOhiway Outlook PST file and Rules Using Outlook 1
M Outlook 2016 Rules Not Working Automatically Using Outlook 5
A outlook 2007 how to chcek all rules ? Outlook VBA and Custom Forms 2
J Outlook Rules not show Master Category List Using Outlook.com accounts in Outlook 4
R Outlook rules Using Outlook 3
M Outlook 2007 IMAP Account Rules Issues Using Outlook 3
D Outlook Rules - How to use a variable in the subject condition Outlook VBA and Custom Forms 9
A Setting RULES with more than one condition in MS OUTLOOK Using Outlook 6
J Outlook rules and alternatives Using Outlook 2
Rupert Dragwater How to delete old rules and create new in Outlook 2013 Using Outlook 12
H Using Outlook Rules to search for NewLines in message body Using Outlook 1
R Outlook - alternatives to Rules / Junk? Using Outlook 5
R Outlook 2013 - IMAP & Rules Broken Using Outlook 1
D Trying to repair Outlook rules Using Outlook 5
V Importing Rules in Outlook 2013 Using Outlook 2
T Adding text to forwarding rules in Outlook 2010 Using Outlook 1
T Adding tex to forwarding rules in Outlook 2010 Exchange Server Administration 1
D Outlook 2010 Rules: fwd meeting invitation results in winmail.dat not .ics Using Outlook 4
M Outlook 2010 IMAP rules occasionaly stop working Using Outlook 4
kburrows Smartphones, Outlook and Rules Using Outlook 0
W Fwd Outlook incomming messages to usb port after Rules and alerts applied Using Outlook 0
P Outlook 2013 rules -- not working reliably -- moving messages to wrong boxes Using Outlook 0
J Outlook 2013 - Rules and Alerts for POP3/IMAP Accounts Using Outlook 1
S Outlook 2010: Message Rules come back next time I restart Outlook Using Outlook 0
D Unable to transfer rules from one Outlook computer to another Using Outlook 5
R Outlook 2013 Rules not working Using Outlook 1
S Outlook 2013 - All rules simply delete the email Using Outlook 1
M Rules in Outlook 2013 Exchange Server Administration 9
K Outlook Cached Mode - can't create rules to move email to another mailbox Using Outlook 2
J Outlook rules help Using Outlook 1
J Outlook - rules and Alerts Using Outlook 1
V Outlook 2010 non working rules Using Outlook 1
M Rules & Alerts not appearing in the File Tab (outlook 2010) Using Outlook 1
S Outlook 2010, need script for rules & Warnings Using Outlook 3
