Rich Locus
Hello Outlook Group:
I am trying to reference a CUSTOM user folder at the same level as all the
other folders:
For example, I have a folder called MyEmails that appears in the Outlook
tree as follows:
Calendar
Contacts
Deleted Items
Drafts
Inbox
MyEmails
The VBA code I'm using from Access works for the Inbox, but fails on the
MAPI setup of the MyEmails Folder:
Set Inbox = OlApp.GetNamespace("Mapi").GetDefaultFolder(olFolderInbox)
Set MyEmailFolder = OlApp.GetNamespace("Mapi").Folders("MyEmail")
I don't want to the the GetDefaultFolder because it isn't one. Does anyone
know the code to create the Namespace for "MyEmail"?
Rich Locus
Rich Locus
Logicwurks, LLC
other folders:
tree as follows:
Calendar
Contacts
Deleted Items
Drafts
Inbox
MyEmails
Rich Locus
Rich Locus
Logicwurks, LLC
