Is there way to merge calendars? or copy by month into another?
Brian Tillman
"Julie" <Julie> wrote in message
news:CC48A3FD-CCEE-4694-AC30-9F2117035A8E@microsoft.com...
> I would like to merge two calendars into a third. Is there a way?
Sure. Open the first calendar, select a table view like By Category or
Events, select all the enteries by pressing Ctrl+A. Copy the selection to the
destination calendar. Repeat with the second calendar.
Forum Admin
Switch to a list view, such as All Appointments or By Category. (Use the View menu or show the Advanced tool bar.)
Click on one item, the press Ctrl+A to select all.
Use the Move to folder (or Copy to folder) command or drag the items to the folder you want to move the items to.
See http://www.slipstick.com/tutorials/merge_cal/merge_cal.htm if you need a tutorial.
