Custom Forms Problem
Tech Support
I have two computers running Office Pro 2007. This is not Exchange and
we do not use public folders. I want to be able to create custom forms
for Tasks and send them to the other computer user. When I create a
custom form modeled after a task and add a second page, the other user
does not see the new page when I send the task to them. When I'm in
design view, I see tabs going accross the top like p.2 and p.3. I make
p.2 visible and create some user defined fields for it. I then save the
form in either a new folder that uses task items or my existing task
folder. I create the task and send it to the other computer. The other
user does not see my custom form in the "Show" section of my task that
has the user defined fields. I have also tried creating the same form
and user defined fields on the other computer and I still don't see the
custom form when I receive the task on that computer. Help appreciated.
*** Sent via Developersdex http://www.developersdex.com ***
It *might* work if both users publish the form to their Personal Forms
library with the same message class and the "send form definition with item"
box unchecked, but it's also quite possible that it won't work. I've always
tried to steer clear of custom task requests.
Sue Mosher
> Thanks!
S Adding Custom Forms Outlook VBA and Custom Forms 4
B Outlook Custom forms Using Outlook 0
Cameron Piper Automatically update custom forms across multiple computers Outlook VBA and Custom Forms 1
N Export Outlook custom forms fields to excel Outlook VBA and Custom Forms 1
Diane Poremsky Designing Custom Outlook Forms Using Outlook 0
Diane Poremsky Publishing Custom Forms Using Outlook 0
Nick Truscott Lost custom forms after moving mailbox Outlook VBA and Custom Forms 3
H Lost Custom Forms when we replaced Exchange Server Outlook VBA and Custom Forms 3
D Using Follup in Custom Forms Outlook 2013 Using Outlook 9
C Custom Forms: Question about retaining form information throughout the entire conversation Outlook VBA and Custom Forms 2
M does outlook 2013/365 on mac support custom forms? Outlook VBA and Custom Forms 1
R Viewing & Using custom forms/tasks in Outlook 2013 Using Outlook 1
LarryH Custom Fields & Forms Using Outlook 3
P Creating custom contact forms Using Outlook 2
M Add custom locations to Outlook Forms "Look In:" drop-down list Using Outlook 5
M Workarounds for sharing custom Outlook 2007 forms? Using Outlook 3
P Unable to delete custom forms in outlook 2010 Using Outlook 1
G Office Profession Plus 2010 is not working for custom forms Using Outlook 3
O Outlook custom forms (2003) Using Outlook 5
A Outlook 2013 corrupting custom forms? Using Outlook 34
J Custom Forms Don't Always Auto-Forward From Public Folder Using Outlook 0
M Custom Forms for Emails Using Outlook 4
K Custom Forms - Blank Message Received! Using Outlook 1
L Custom Forms Using Outlook 3
S Can I link custom designed forms to a specific calendar? Using Outlook 5
K Find vs. custom forms Outlook VBA and Custom Forms 2
T Custom Contact Forms and User Properties Outlook VBA and Custom Forms 2
B Macros have been disabled error Message with Custom forms Outlook VBA and Custom Forms 17
G Custom Forms: Attachment to be included in Reply Outlook VBA and Custom Forms 1
S Custom VBA forms in Outlook--how to call w/macro? Outlook VBA and Custom Forms 1
Q More than one Notes section in custom contact forms Outlook VBA and Custom Forms 1
O custom forms Outlook VBA and Custom Forms 2
A How to reduce size of custom contact form? Outlook VBA and Custom Forms 3
