vba timing
bobh
On a daily basis I recieve emails which have spreadsheet attachments,
these emails I want to move to another Outlook folder and save the
attachment to a folder on my 'c:' disk drive.
I have vba code to save the attachment and I created a rule for when
the 'subject' line contains specific text to move it to the other
Outlook folder and run a vba sub which calls another sub which does
the actual work, see below(ps: I got this code from someplace on the
web).
I believe this code/process will work but I'm having one issue which
is
the rule says
Apply this rule after the message arrives
with testtry in the subject
and on this machine only
move it to the MyTestFolder folder
and run Project1.TestSave
So, when an email is recieved in my inbox which has 'testtry' in the
subject line it moves it to the 'MyTestFolder' but before it completes
that move it start to run the vba sub 'TestSave' which passes the
values to the sub SaveEmailAttachmentsToFolder and starts to run it
before the rule has finished moving the email to the folder so the sub
SaveEmailAttachmentsToFolder does not find any emails in MyTestFolder
so I end up getting the "MsgBox "There are no messages in this folder
" message from the sub.
How do I make the rule finish moving the email before it starts
running the script???
Public Sub TestSave(msg As MailItem)
'Arg 1 = Folder name in your Inbox
'Arg 2 = File extension, "" is every file
'Arg 3 = Save folder, "C:\Outlook\MyFiles" or ""
'If you use "" it will create a date/time stamped folder for you in
the "My Documents" folder.
'Note: If you use this "C:\Outlook\MyFiles" the folder must exist
SaveEmailAttachmentsToFolder "MyTestFolder", "xls", "C:\BH-Outlook
\TestSave"
Public Sub SaveEmailAttachmentsToFolder(OutlookFolderInInbox As
String, ExtString As String, DestFolder As String)
On Error GoTo ThisMacro_err
'Do not change code in the macro below
Dim ns As NameSpace
Dim Inbox As MAPIFolder
Dim SubFolder As MAPIFolder
Dim Item As Object
Dim Atmt As Attachment
Dim FileName As String
Dim MyDocPath As String
Dim I As Integer
Dim wsh As Object
Dim fs As Object
Set ns = GetNamespace("MAPI")
Set Inbox = ns.GetDefaultFolder(olFolderInbox)
Set SubFolder = Inbox.Folders(OutlookFolderInInbox)
I = 0
' Check subfolder for messages and exit of none found
If SubFolder.Items.Count = 0 Then
MsgBox "There are no messages in this folder : " &
OutlookFolderInInbox, vbInformation, "Nothing Found"
Set SubFolder = Nothing
Set Inbox = Nothing
Set ns = Nothing
'Create DestFolder if DestFolder = ""
If DestFolder = "" Then
Set wsh = CreateObject("WScript.Shell")
Set fs = CreateObject("Scripting.FileSystemObject")
MyDocPath = wsh.SpecialFolders.Item("mydocuments")
DestFolder = MyDocPath & "\" & Format(Now, "dd-mmm-yyyy hh-mm-
ss")
If Not fs.FolderExists(DestFolder) Then
fs.CreateFolder DestFolder
If Right(DestFolder, 1) <> "\" Then
DestFolder = DestFolder & "\"
' Check each message for attachments and extensions
For Each Item In SubFolder.Items
For Each Atmt In Item.Attachments
If LCase(Right(Atmt.FileName, Len(ExtString))) =
LCase(ExtString) Then
FileName = DestFolder & Item.SenderName & " " &
Atmt.FileName
Atmt.SaveAsFile FileName
I = I + 1
Next Atmt
Next Item
' Show this message when Finished
If I > 0 Then
MsgBox "You can find the files here : " _
& DestFolder, vbInformation, "Finished!"
MsgBox "No attached files in your mail.", vbInformation,
"Finished!"
' Clear memory
ThisMacro_exit:
Set Inbox = Nothing
Set ns = Nothing
Set fs = Nothing
Set wsh = Nothing
' Error information
ThisMacro_err:
MsgBox "An unexpected error has occurred." _
& vbCrLf & "Please note and report the following
information." _
& vbCrLf & "Macro Name: SaveEmailAttachmentsToFolder" _
& vbCrLf & "Error Number: " & Err.Number _
& vbCrLf & "Error Description: " & Err.Description _
, vbCritical, "Error!"
Resume ThisMacro_exit
In TestSave you already have a reference to the email (see the msg
variable). Pass that to the SaveEmailAttachmentsToFolder procedure, and
handle only that one item. Then you don't need to loop through the entire
inbox.
Best regards
Michael Bauer
Am Mon, 17 May 2010 11:41:41 -0700 (PDT) schrieb bobh:
> Hi,
> web).
> is
> the rule says
> \TestSave"
> End Sub
> Dim ns As NameSpace
> Dim Item As Object
> Dim I As Integer
> Dim wsh As Object
> Dim fs As Object
> I = 0
> Set Inbox = Nothing
> Set ns = Nothing
> Exit Sub
> End If
> ss")
> End If
> End If
> End If
> Atmt.FileName
> I = I + 1
> End If
> Next Atmt
> Next Item
> If I > 0 Then
> Else
> "Finished!"
> End If
> ' Clear memory
> ThisMacro_exit:
> Set Inbox = Nothing
> Set ns = Nothing
> Set fs = Nothing
> Set wsh = Nothing
> Exit Sub
> ' Error information
> ThisMacro_err:
> information." _
> End Sub
On May 18, 2:43 am, "Michael Bauer " <m...@mvps.org
> inbox.
> > Best regards
> Michael Bauer
>   Category Manager -
>   SAM - The Sending Account Manager:
> > Hi,
> > web).
> > is
> > the rule says
> > \TestSave"
> > End Sub
> >     Dim ns As NameSpace
> >     Dim Item As Object
> >     Dim I As Integer
> >     Dim wsh As Object
> >     Dim fs As Object
> >     I = 0
> >         Set Inbox = Nothing
> >         Set ns = Nothing
> >         Exit Sub
> >     End If
> > ss")
> >         End If
> >     End If
> >     End If
> > Atmt.FileName
> >                 I = I + 1
> >             End If
> >         Next Atmt
> >     Next Item
> >     If I > 0 Then
> >     Else
> > "Finished!"
> >     End If
> > ' Clear memory
> > ThisMacro_exit:
> >     Set Inbox = Nothing
> >     Set ns = Nothing
> >     Set fs = Nothing
> >     Set wsh = Nothing
> >     Exit Sub
> > ' Error information
> > ThisMacro_err:
> > information." _
> > End Sub-
I assume you mean here and unfortunetly I don't know how to do that. I
don't really know Outlook vba. What would the vba code be to select
and check the "msg as Mailitem" before moving it the the subfloder?
Atmt.FileName
I = I + 1
Next Atmt
Next Item
In this function replace
by
Public Sub SaveEmailAttachmentsToFolder(Item as MailItem, ExtString As
and remove the outer loop, the one through the SubFolder.Items collection.
Best regards
Michael Bauer
Am Wed, 19 May 2010 09:31:37 -0700 (PDT) schrieb bobh:
> > inbox.
>> > > Best regards
> > Michael Bauer
> >   Category Manager -
> >> Hi,
> >> web).
> >> is
> >> the rule says
> >> \TestSave"
> >> End Sub
> >>     Dim ns As NameSpace
> >>     Dim Item As Object
> >>     Dim I As Integer
> >>     Dim wsh As Object
> >>     Dim fs As Object
> >>     I = 0
> >>         Set Inbox = Nothing
> >>         Set ns = Nothing
> >>         Exit Sub
> >>     End If
> >> ss")
> >>         End If
> >>     End If
> >>     End If
> >> Atmt.FileName
> >>                 I = I + 1
> >>             End If
> >>         Next Atmt
> >>     Next Item
> >>     If I > 0 Then
> >>     Else
> >> "Finished!"
> >>     End If
> >> ' Clear memory
> >> ThisMacro_exit:
> >>     Set Inbox = Nothing
> >>     Set ns = Nothing
> >>     Set fs = Nothing
> >>     Set wsh = Nothing
> >>     Exit Sub
> >> ' Error information
> >> ThisMacro_err:
> >> information." _
> >> End Sub-
> Atmt.FileName
> I = I + 1
> End If
> Next Atmt
> Next Item
J Outlook VBA to send from Non-default Account & Data Files Outlook VBA and Custom Forms 3
Geldner Problem submitting SPAM using Outlook VBA Form Outlook VBA and Custom Forms 2
