ItemAdd event not functioning - not triggering.
BlueWolverine
MS OUTLOOK 2003 on XP PRO.
What I'm trying to do:
I want to take every email I send, move it to a PST folder, and mark as read
using VBA since this isn't possible in a rule (specifically mark as read).
My Problem:
Through this forum and some other places, I think I have code that's at
least close to doing this. The problem is, the darn thing never triggers.
Please help me with this code. Thank you.
All of what follows is the entirety of a class module.
Dim myolApp As New Outlook.Application
Public WithEvents myOlItems As Outlook.Items
Public Sub Initialize_handler()
Set myOlItems =
myolApp.GetNamespace("MAPI").GetDefaultFolder(olFolderSentMail).Items
Public Sub myOlItems_ItemAdd(ByVal Item As Object)
Dim myInbox As Outlook.MAPIFolder
Dim myFolder As Outlook.MAPIFolder
Dim myNewFolder As Outlook.MAPIFolder
Set myFolder = myNameSpace.GetDefaultFolder(olFolderSentMail)
Set myInbox = myNameSpace.GetDefaultFolder(olFolderInbox)
Set myNewFolder = myInbox.Folders("EMAIL")
Item.Move myNewFolder
Item.UnRead = False
Item.Save
Debug.Print Item.Subject
BlueWolverine
MSE - Mech. Eng.
Go BLUE!
First things first. If this is running in the Outlook VBA project use the
intrinsic, trusted Application object. Don't use New.
If the code is in a class then are you instantiating an instance of the
class and calling the init code? Usually you'd put the code in the
ThisOutlookSession class, which is automatically instantiated. Then you'd
call your init handler code from the Application_Startup() event handler,
which is automatically available in ThisOutlookSession.
"BlueWolverine" <BlueWolverine> wrote in message
news:99E4EA6A-5FE7-4CEE-A99F-4BEE407F9D22@microsoft.com...
> Hello,
> read
> My Problem:
> Set myOlItems =
> End Sub
> Item.UnRead = False
> Item.Save
> End Sub
> > BlueWolverine
> MSE - Mech. Eng.
> Go BLUE!
Hi!
I can not understand, why you want to Mark Item as READ if it is
already marked as READ by default after you sent it?
You can use intrinsic routine ItemSend in class ThisOutlookSession for
catch sent items "on-fly" and set Item.SaveSentMessageFolder to folder
you needed.
However, if You definitely want to set Item.Unread Property to false,
you have to use ItemAdd event for that.
Example:
Private Sub Application_ItemSend(ByVal Item As Object, Cancel As
Boolean)
Set Item.SaveSentMessageFolder =
Application.GetNamespace("MAPI").Folders(Outlook
Folders).Folders("Inbox").Folders("MyFolder")
' Also You can set Flag to some Color, If You need point it
Item.FlagIcon = olGreenFlagIcon
Again! You can write code string
Item.Uread=False/True
within this proc, but it will overwrite by Outlook on sending to False
-Regards, Andrey
oliv- Treat once an email with the ItemAdd event in a shared mailbox Outlook VBA and Custom Forms 2
R outlook 2007 itemadd event handler fails to run Outlook VBA and Custom Forms 2
Diane Poremsky How to use an ItemAdd Macro Using Outlook 0
A ItemAdd on Imap Folder get endless loop after saving item Using Outlook 5
J Calendar events created on iPhone automatically changing default alert from 'None' to 'Time of Event' Using Outlook.com accounts in Outlook 0
T How to get an EVENT COLOR option in Outlook 2021 ? Using Outlook 0
J Cannot edit a calendar event received as an invitation Using Outlook 2
T Event Error on non existent Event. Using Outlook 2
J Event/Meeting in Outlook Does Not Align with SharePoint Calendar Using Outlook 5
P Calendar Day View only shows 1 all day event Using Outlook 0
G Event when creating task from mailitem Outlook VBA and Custom Forms 2
J Outlook 2010 Outlook/Win7 Client logging Event ID 36887 Using Outlook 0
K Recurring all day annual event Using Outlook 3
P Restore an individual all-day recurring event Using Outlook 2
K Working with Explorer.Close event Outlook VBA and Custom Forms 3
F Outlook 2016 call to Stop Timer Event Outlook VBA and Custom Forms 4
D Event ID issues Exchange Server Administration 2
J ItemChange event Outlook VBA and Custom Forms 11
T Outlook 2016 Calendar multiday event display Using Outlook 4
M Automatically create event in calendar when task is created Outlook VBA and Custom Forms 1
A UID field in iCal files - unique per-event or per-user or both? Using Outlook 2
B on flag message event - create task Outlook VBA and Custom Forms 22
Diane Poremsky Change the All Day Event Default Free/Busy to "Busy" Using Outlook 3
C Calendar - Centering an event in Outlook? Using Outlook 1
J Outlook calendar...How to add an event or appointment without a border around it? Using Outlook 9
J Create Calendar Alert Event form Mail Subject line? Using Outlook 4
S Item Add Event fires intermittently Outlook VBA and Custom Forms 3
R Why is a meeting organizer me and not the creator of the event? Using Outlook 1
V Calendar event acting odd Using Outlook 7
G Capture "forward event" ? Outlook VBA and Custom Forms 11
P Change the Outlook.com "from" address for calendar event invites Using Outlook 9
20 Ton Squirrel Detect Application_Startup event completion Outlook VBA and Custom Forms 1
L Outlook 2007 All Day Event Using Outlook 27
I Event listener for deleted items Using Outlook 6
M Save Attachments Event? Using Outlook 0
Commodore Calendar Folder property is missing - Event 27 Using Outlook 11
G Quit event code - 2007 Using Outlook 3
J Capturing forward event when multiple items are selected Using Outlook 0
P Trying to get 'Calendar Name' to appear like 'Subject' and 'Location' in event Using Outlook 0
G What event happens when you open 2 copies of your inbox? Using Outlook 5
D Adding a participant automatically to a calendar event Using Outlook 1
H Changing Organizer of event (for single to total calendar move; long way ) Exchange Server Administration 4
N Combobox in outlook add ons toolbar not firing event on main window resized Using Outlook 3
D Extracting Location info from All Day Event in mailboxes into webpage Exchange Server Administration 3
H Conflicts with other event in calendar ( outlook 2007 &amp; 2010) Using Outlook 0
