BlueWolverine
MS OUTLOOK 2003 on XP PRO
Awhile ago I was looking for how to do this and it was irritating me that it
was so hard to get a straight answer on how to pull this routine together.
So I thought I'd post sample code here to let everyone now how to do this
VERY simple thing.
Note: Occassionally, this thing de-initializes and won't trigger. If that
happens your email goes to your sent mail folder on the server side same as
always. No biggie, just close and re-open outlook to re-initialize or
manually run through the sub Application_Startup in the ThisOutlookSession
object. If I figure out how to prevent this from ever happening, I will
repost with better code.
I hope this is helpful to others. It really irked me that I couldn't find
seemingly simple sample code for this, so I thought I'd publish.
***I make no claims on the stability of this code, or it's reliability in
never causing problems. I believe it works well on my machine, and I think
it will work on yours but I have not rigorously tested it or done any
official software testing exercises. I am not responsible if this routine
eats your email by mistakes. It's not supposed to, but I don't KNOW that it
won't. Use at your own risk.
Macro to Mark as Read and Move to Archive Folder...
Copy and paste this to Objects 'This Outlook Session'
Dim classHandler As New cls_SentMail
Private Sub Application_StartUp()
classHandler.Initialize_handler
Put in Class Module named 'cls_SentMail'
Dim myolApp As New Outlook.Application
Public WithEvents myOlItems As Outlook.Items
Public Sub Initialize_handler()
Set myOlItems =
myolApp.GetNamespace("MAPI").GetDefaultFolder(olFolderSentMail).Items
Public Sub myOlItems_ItemAdd(ByVal Item As Object)
Dim myNewFolder As Outlook.MAPIFolder
Dim myNameSpace As Outlook.NameSpace
Dim str_path As String
Dim str_pst As String
Dim str_folder As String
' User Defined Variables
str_path = "XXXXXXX.pst" 'This is the complete filepath for the PST
file you are using as an archive
str_pst = "Current" 'This is the name of the PST file as it
appears in the OUTLOOK window, below your inbox
str_folder = "Email" 'This is the name of the folder inside
str_pst that you want sent email move to.
Set myNameSpace = myolApp.GetNamespace("MAPI")
myNameSpace.AddStore (str_path)
Set myNewFolder = myNameSpace.Folders(str_pst).Folders(str_folder)
Item.Move myNewFolder
Item.UnRead = False
Item.Save
'Debug.Print Item.Subject
BlueWolverine
MSE - Mech. Eng.
Go BLUE!
VERY simple thing.
Set myOlItems =
Item.UnRead = False
Item.Save
BlueWolverine
MSE - Mech. Eng.
Go BLUE!
