userform combobox
  • Thread starter Jonathan
  • Start date Views 1,685
Jonathan
Hi, using Outlook 2007. I have a simple userform that only has a combobox.
The problem is that I cannot enter a value and cannot select an item from the
list.
Enable=true
Locked=false
I don't know if this is a red herring... the multi-column combobox is loaded
using data from sql2005
Do Until rsClient.EOF
cboClientList.AddItem
For columnIndex = 0 To fieldCount
cboClientList.List(rowIndex, columnIndex) =
rsClient.Fields(columnIndex) & ""
Next columnIndex
rsClient.MoveNext
rowIndex = rowIndex + 1
Loop
The combobox has 4 columns that are all visible.
Any ideas or suggestions appreciated :)
Many thanks,
Jonathan
Jonathan
I found it... it was my on change event that was causing issues...
thanks,
Jonathan
> list.
> Enable=true
> Locked=false
> Next columnIndex
> rsClient.MoveNext
> Loop
> Many thanks,
> Jonathan
