UserForm and ordering variables
C
Chris
I need help with ordering an set of variables (strSend,strSubj,StrTime) and
keeping them in that order. I use a userform to allow the user to select one
of the ten formats and assign the order to the variable FileNameFormat
(FileNameFormat = strTime & "_" & strSend & "_" & strSubj). The problem is
that the FileNameFormat takes the values of the variables once and will not
update with the new data as the loop is run (NewFileName = FileNameFormat &
".msg"). Is there a way to store the order of variables in another variable
to be able to assign the values of those stored variables as they change?
-----Variable Declarations---
Global FileNameFormat As Variant
Global strSubj, strTime, strSend, mailClassCheck, EmailPath As String
Global RunOnce As Boolean
-----Module Code---
Public Sub ExportSAR()
Dim TheEmail As Object
Dim ReportEmail As ReportItem
Dim eItem As Outlook.Items
Dim EmailNS As NameSpace
Dim fldrCount, EmailPath2, NbrItem, myfolder
Dim NewFileName, ReportHeader As String
Dim Cats
Dim CheckErr, Exists As Boolean
CheckErr = False
RunOnce = False
Set EmailNS = Application.GetNamespace("MAPI")
Set myfolder = Application.ActiveExplorer.CurrentFolder
NbrItem = myfolder.Items.Count
On Error GoTo Error_Handler
EmailPath = BrowseForFolderShell
'FileName.Show
'MsgBox FileNameFormat
'MsgBox EmailPath, vbOKCancel
'EmailPath = InputBox("Enter the save folder location:", "Email Save
Path", CurDir)
For i = 1 To NbrItem
Set TheEmail = Application.ActiveExplorer.CurrentFolder.Items.Item(i)
'MsgBox Len(TheEmail.SenderName) & Chr$(13) & Len(TheEmail.Subject) &
Chr$(13) & Len(TheEmail.ReceivedTime)
'MsgBox TheEmail.SenderName & Chr$(13) & TheEmail.Subject & Chr$(13) &
TheEmail.Categories = TheEmail.Categories & ";" & "Red Category"
mailClassCheck = TheEmail.MessageClass
If Left(mailClassCheck, 6) = "REPORT" Or Left(mailClassCheck, 6) =
"Report" Then
Set ReportEmail =
If ReportEmail.Subject = "" Then strSubj = "no subject"
If Right(ReportEmail.MessageClass, 2) = "DR" Then ReportHeader =
"DeliveryReport" Else ReportHeader = "Read Receipt"
strSubj = Replace(ReportEmail.Subject, "/", "-")
strSubj = Replace(strSubj, "\", "-")
strSubj = Replace(strSubj, ":", "--")
strSubj = Replace(strSubj, "?", sReplace)
strSubj = Replace(strSubj, "*", sReplace)
strSubj = Replace(strSubj, Chr$(34), sReplace)
'strSubj = Replace(strSubj, Chr$(9), sReplace)
strSubj = Replace(strSubj, "<", sReplace)
strSubj = Replace(strSubj, ">", sReplace)
strSubj = Replace(strSubj, "|", sReplace)
strTime = Replace(ReportEmail.CreationTime, "/", "-")
strTime = Replace(strTime, "\", "-")
strTime = Replace(strTime, ":", ".")
strTime = Replace(strTime, "?", sReplace)
strTime = Replace(strTime, "*", sReplace)
strTime = Replace(strTime, Chr$(34), sReplace)
strTime = Replace(strTime, "<", sReplace)
strTime = Replace(strTime, ">", sReplace)
strTime = Replace(strTime, "|", sReplace)
NewFileName = ReportHeader & "_" & strSubj & strTime & ".msg"
If NewFileName <> "" Then
ReportEmail.SaveAs EmailPath & NewFileName, olMSG
MsgBox "No file name was entered. Operation aborted.", 64,
"Cancel Operation"
GoTo Step1
If TheEmail.Subject = "" Then strSubj = "no subject"
strSend = Replace(TheEmail.SenderName, "/", "-")
strSend = Replace(strSend, "\", "-")
strSend = Replace(strSend, ":", "--")
strSend = Replace(strSend, "?", sReplace)
strSend = Replace(strSend, "*", sReplace)
strSend = Replace(strSend, Chr$(34), sReplace)
strSend = Replace(strSend, "<", sReplace)
strSend = Replace(strSend, ">", sReplace)
strSend = Replace(strSend, "|", sReplace)
strSubj = Replace(TheEmail.Subject, "/", "-")
strSubj = Replace(strSubj, "{", sReplace)
strSubj = Replace(strSubj, "}", sReplace)
strSubj = Replace(strSubj, " ", sReplace)
strTime = Replace(TheEmail.ReceivedTime, "/", "-")
'NewFileName = strSend & "_" & strTime & "_" & strSubj & ".msg"
If RunOnce = False Then
FileName.Show
RunOnce = True
NewFileName = FileNameFormat & ".msg"
If Len(NewFileName) > 160 Then
TooLong:
NewFileName = InputBox("Please Enter a New File Name that is
shorter than 161 characters." & Chr$(13) & "Current file name is " &
Len(NewFileName) & "characters.", _
"File Name Too Long", NewFileName)
MsgBox "File name is still too long." & Chr$(13) & "Current file
name is " & Len(NewFileName) & "characters.", vbOKOnly, "File Name is Too
Long"
GoTo TooLong
TheEmail.SaveAs EmailPath & NewFileName, olMSG
"Cancel Operation"
Step1:
strSubj = ""
strTime = ""
Next i
GoTo Done
Error_Handler:
If TheEmail Is Nothing Then
MsgBox Err.Number & ":" & Err.Description
TheEmail.Categories = TheEmail.Categories & ";" & "Not Copied"
MsgBox TheEmail.MessageClass & Chr$(13) & Len(NewFileName) & Chr$(13) &
Chr$(13) & strSend & Chr$(13) & strTime & Chr$(13) & TheEmail.Subject &
Chr$(13) & strSubj & Chr$(13) & Err.Number & ": " & Err.Description
TheEmail.Save
Resume Next
Done:
-----UserForm Code---
Private Sub Submit_Click()
Select Case FileFormat
Case DateSendSubj
Case DateSubj
FileNameFormat = strTime & "_" & strSubj
Case DateSubjSend
FileNameFormat = strTime & "_" & strSubj & "_" & strSend
Case SendDateSubj
FileNameFormat = strSend & "_" & strTime & "_" & strSubj
Case SendSubj
FileNameFormat = strSend & "_" & strSubj
Case SendSubjDate
FileNameFormat = strSend & "_" & strSubj & "_" & strTime
Case SubjDate
FileNameFormat = strSubj & "_" & strTime
Case SubjDateSend
FileNameFormat = strSubj & "_" & strTime & "_" & strSend
Case SubjSend
FileNameFormat = strSubj & "_" & strSend
Case SubjSendDate
FileNameFormat = strSubj & "_" & strSend & "_" & strTime
Me.Hide
Sue Mosher [MVP]
Why not just declare the variables strTime, strSend, and strSubj as global
variables?
Sue Mosher
> -----Variable Declarations---> Global FileNameFormat As Variant
> -----Module Code---> Public Sub ExportSAR()
> Dim Cats
> CheckErr = False
> RunOnce = False
> 'FileName.Show
> Path", CurDir)
> "Report" Then
> Set ReportEmail =
> Else
> "Cancel Operation"
> Exit Sub
> End If
> GoTo Step1
> End If
> FileName.Show
> RunOnce = True
> End If
> TooLong:
> Long"
> GoTo TooLong
> Else
> End If
> Else
> End If
> Else
> "Cancel Operation"
> Exit Sub
> End If
> Step1:
> strSubj = ""
> strTime = ""
> Next i
> GoTo Done
> Error_Handler:
> Else
> TheEmail.Save
> End If
> Resume Next
> Done:
> End Sub
> -----UserForm Code---> Private Sub Submit_Click()
> Case DateSendSubj
> Case DateSubj
> Case DateSubjSend
> Case SendDateSubj
> Case SendSubj
> Case SendSubjDate
> Case SubjDate
> Case SubjDateSend
> Case SubjSend
> Case SubjSendDate
> End Select
> Me.Hide
> End Sub
Sue Mosher [MVP]
Sorry, but I really can't see the problem here, because I don't know what the
user interaction might be in your scenario. Maybe you should step away from
the keyboard and sketch out a flow chart that includes those interaction
points. In other words, how does "the new data" you described in your
original post get injected into the process? Once you can visualize that, I
suspect you'll see the solution, too -- or at least be able to communicate
more information to us.
Sue Mosher
"Chris" wrote:
> Sue,
> They are declared as Global Variables. The problem is that the order I use
> them in to create the file name, can change. I can get the name correct once
> but I need to know how to refresh the data every time the FileNameFormat
> variable is called after initializing it.
> Example:
> Some users may want:
> strSend & "_" & strSubj & "_" strTime
> Other users may want:
> strSend & "_" strTime & "_" & strSubj
> and yet others may want:
> I need a way to accommodate all possibilities of the order of the variables.
> > variables?
C
Chris
Sue,
I figured it out. I set a flag to the variable FileNameFormat on the
userform and then use Select Case FileNameFormat back in the module to set
the filename.
Chris
> > Sue Mosher
> "Chris" wrote:
> > Sue,
> > Example:
> > > variables?
