How to display reminders at startup
  • Thread starter Corbie999
  • Start date Views 706
C
Corbie999
Under Windows XP and using MS Works Calendar, reminders appeared at startup. After switching to Windows 7 and office this does not happen,. Can it be set up to display reminders when the system is switched on?
C
Corbie999
I am using Outlook at present and have discovered , as you point out that reminders will not appear unless I start Outlook. I also have Works Calendar available and this did fire up reminders when the (XP) system was switched on, however this does not seem to be the case under Windows 7. Is this simply a matter of getting Works Reminders into the Startup Group? If so how?
Ted
Ted
I'm not real familiar with Works - it may be that it doesn't work with Win7. Works uses a small reminder application that loads at start up. Before I'd add it to the startup group, i'd check its options and see if you can set it to load at start up.
ETA: it looks like its a problem with Windows 7. See if this post helps - http://social.answers.microsoft.com/Forums/en-US/w7programs/thread/042fed6e-1711-4a05-81ac-14b0c59d3b7d#e9d9f6be-26b9-41d9-ab57-10e896a8727b
C
Corbie999
Many thanks, the post you referred me to has resolved the issue
