Searching and sorting.
byars
Outlook 2007 is not returning newly added contacts as part of a "search" or "sort". This happens whether I add a "New contact from Same Company" or just add "New Contact". The results of my searchs/sorts return the older contacts that were alreay in my Contacts, but will not return any contacts that have been added. I can see the added contact(s) are there and I can go to them directly, but they are not returned within a search or sort.
Russ Valentine
"my search/sorts" really doesn't tell us anything. Clarify to which search method you are referring. Define what Sort method you are using.Russ Valentine
