Changing folder layout/colors.
  • Thread starter broberts0295
  • Start date Views 675
broberts0295
I would like to chnage the colors of folders I have created under my Inbox header to help identify various types of information within the folders. Can I change the folder icon's colors?
No, folder icons cannot be modified. If using colors to differentiate your Outlook information is ideal for you, consider using Categories or even Conditional Formatting in a View (where you can change the color/font/size of the message in the list within the folder based on certain critieria, like messages from certain people).(P.S. Please don't forget to mark this post as an answer if it has helped you)
Eric Legault: MVP (Outlook), MCTS (SharePoint)
Owner: Collaborative Innovations
Twitter: elegault
Blog: Eric Legault My Eggo
