Body of email messages are missing when you forward or reply to it.
P
patti370
When you reply to or forward an e-mail message in Microsoft Outlook, the e-mail message is missing.
For example, if you forward an e-mail message, the text is missing from the body of the original e-mail message that you are forwarding when it is received. Additionally, if you forward an e-mail message, the text is missing from the body of your reply e-mail message when it is received.
Brian Tillman
Check the font to see if you're using a font the same color as the background. Also, if you have your antivirus program configured to scan mail, uninstall it and reinstall it without that feature.
Ruchi Bisht
Try the steps mentioned below:
1. Open outlook.
2. Click on Tools at the top->Options-> Mail Format.
3. Click Stationery and Fonts.
4. Under Replying or forwarding messages, click Fonts.
5. Click on Font color and select Automatic and click ok.
Hope this helps.
Ruchi Bisht
