have been receiving 'Not Responding' message on both home and office computers and business and personal accts. Have Vista business on one s
Dan Brooks
The "not Responding" hang up sems to be a common problem. I encounter it often at office and home and have had similar from many friends/associates. Problem started about 6 months ago and continues even though all updates done. Occurs both intranet and internet based access.
P
Palcouk
Try starting outlook using the safe switch and see if the problem is replicated - Its such a common problem I've never experienced it; from OL98 to OL2007 in win2k to win7
G
Guruprasad Ra
Step1:
If applications safe works fine, try disabling add-ins for Office application.
Check the following link to know more about how to run Office applications in safe mode and disabling add-ins
http://office.microsoft.com/en-us/outlook/HP101407921033.aspx
http://office.microsoft.com/en-us/help/HA100341271033.aspx
Step 2:
If application safe fails to address the issue then try performing windows safe mode and check if you are able to work with Office applications
Check the following link to know more about performing windows safe mode
Note: After you have finished troubleshooting in windows safe mode, ensure you restart the computer in normal mode.
http://windows.microsoft.com/en-US/windows-vista/Start-your-computer-in-safe-mode
If you are able to work in safe mode then this issue is caused by a Non-Microsoft Service
