empty e-mails are showing up in my inbox, when opened it has no text, no to or from and when opened shows 'sent: none' and takes up 199B, ho
  • Thread starter Florida Outlook Issue
  • Start date
F
empty e-mail is showing up in my inbox, when opened it has no text, no to or from and when opened shows "sent: none" and takes up 199B I am using Outlook 2003 with SP3 and Windows 7
How do I stop this? Am I infected?
Ruchi Bisht
What type of email account you have? (E.g. POP, IMAP etc...)
If you are using Hotmail account, you can try to disable your virus scanner's integration with Outlook.
If you are not able to disable it, remove the email account from Outlook and uninstall Outlook connector and reinstall.
1. Exit Outlook.
2. Click Start->Control panel->program ->program and features and uninstall Microsoft Outlook connector.
3. Download the latest version of Outlook connector and reconfigure the account http://www.microsoft.com/downloads/details.aspx?FamilyID=39db2b89-af2e-41f9-a175-f93e1377959f&displaylang=en.
Ruchi Bisht
