anyone having problems connecting to hotmail server. I wasn't able to after more than 15 minutes.
N
Not You2
Ive got the Connector Version 14.0.xxx
Outlook was stuck in Send/Receive Status 49% for more than 45 minutes last night. I ultimately ended the task and now its doing the same thing in safe mode. I don't have any of the emails I got yesterday or today in the inbox and my server status says Connecting for all three items.
Roady [MVP]
There are several things you can try here;
Do you have a virus scanner installed which integrates itself with Outlook? Uninstall this integration part of your virus scanner and try again; you'd still be sufficiently protected by your on-access scanner part of the virus scanner. For more details see;
http://www.msoutlook.info/question/20Locate the srs-file of you mail profile and reset it by renaming it to .old when Outlook is closed. You can find it here;
C:\Documents and Settings\%username%\Application Data\Microsoft\Outlook\ Recreate your mail profile. For details see;
http://www.howto-outlook.com/faq/newprofile.htm
