1. Here's a thread that needs an answer: Print Monthly or Work Week Calendars
Outlook web access will not send, forward etc
Discussion in 'Using Outlook' started by caden2010, Jun 11, 2010.
  1. caden2010
    caden2010
    Guest
    I am using Windows 7 64 bit. I work remotely and have to use Outlook Web Access daily. OWA opens correctly and appears to be OK until I attempt to send, forward email etc. At this point OWA basically stops responding and will close. On "new" email I have only a small red X in the top left corner of the interface window. The situation is similar in 32 bit.
    Please help. This has always worked on XP perfectly.
    I have been looking at various forums to no avail.
    thanks
  2. Richard G. Harper
    Richard G. Harper
    Guest
    This is a known issue with OWA and will require your system administrator to
    install updates to OWA. A quick Bing search revealed this:
    http://blogs.msdn.com/b/ie/archive/...k-web-acess-owa-on-ie7-and-windows-vista.aspx
    "caden2010" wrote in message
    news:660cae7e-0a66-40f2-801f-cecd7c3986af@communitybridge.codeplex.com...
    thanks
  3. caden2010
    caden2010
    Guest
    Hello Richard,
    thank you for the reply but get an error message upon running the exe file. "Not enough storage available to process this command". I am logged in as administrator and am running Windows 7 Pro with 8GB ram.
    Any thoughts?
Loading...
Share This Page
