How to keep the system tray icon running when Outlook is closed?
  • Thread starter TWF4c3N0ZXI
  • Start date Views 3,281
TWF4c3N0ZXI
#1
The system tray icon is removed when I close Outlook so I am not receiving
Calendar timer/reminders.
How can I correct this?
G
Gordon
#2
"Maxsster" <Maxsster> wrote in message
news:FE77C277-1DCD-4F5A-ADC0-4A543A00D63D@microsoft.com...
> Thank you
You can't. Outlook MUST be running for Outlook to work. How else would it
work?
Asking a question?
Please tell us the version of the application you are asking about,
your OS, Service Pack level
and the FULL contents of any error message(s)
RXJvbA
#3
Re: How to keep the system tray icon running when Outlook is close
Maxsster is trying to say: I want the application running, he just doesn't
want to see MS Outlook minimized on taskbar but instead next to clock (like
MSN Messenger). :)
> > Thank you
> work?
> > Asking a question?
TWF4c3N0ZXI
#4
Thanks for your answer Gordon. I was hoping that Outlook had a similar
function to the Palm Desktop Alarm Manager. This allows a Alarm (timer) pop
up when the Palm Desktop program is closed.
Thanks again.
> > Thank you
> work?
> > Asking a question?
#5
news:4200C089-0FDD-40E9-BD6E-695B29DDF6B3@microsoft.com...
It doesn't. It must be running. However, if you have Outlook 2002-2007, you
can configure it to minimize to the Notification Area (System Tray) instead of
to the Taskbar. For Outlook 2003-2007, right-click the Outlook icon in the
system tray and choose "Hide When Minimized". Then use the Minimize button
(not the Close button) to hide it. For Outlook 2002, there's a registry
setting that controls it.
TWF4c3N0ZXI
#6
> Thank you so much Brian, this solved the problem perfectly!
