1. Here's a thread that needs an answer: Print Monthly or Work Week Calendars
OWA not working - blank page
Discussion in 'Exchange Server Questions' started by Shawn Gradwell, May 18, 2010.
  1. Shawn Gradwell
    Shawn Gradwell
    Guest
    When I am on the internal network the browser gives a certificate error but ives me the option to proceed anyway, if I do proceed a blank page occurs and the adress is " https://arwen/owa/auth/logon.aspx?url=https://arwen/owa/&reason=0" arwen is our mail server. This is a brand new 2010 install on a new 2008 SP2 server installation. I have re-created the certificate, it's self signed, if this is a problem please help me to buy one or tell me how I can fix it. But at the moment the blank page is my problem. I have checked all relevant components and all seem working correctly and created right. All normal mail is working well, please help me get OWA online. Much appreciated. S
  2. busbar
    busbar
    Guest
    re-apply RU3 and restart IIS and try again.
    sometroubleshooting for rebuilding the OWA virtual directory is here:
    http://social.technet.microsoft.com/Forums/en-US/exchange2010/thread/4a56414a-b7a4-44ff-b227-76e8e463d506/
    Regards, Mahmoud Magdy Watch Arabic Level 300 Videos about Exchange 2010 here: http://vimeo.com/user3271816 Read pretty advanced Exchange stuff I and other MVPs post here: http://www.enowconsulting.com/ese/blog.asp Or follow my blog: http://busbar.blogspot.com or our corp blog: http://ingazat.wordpress.com and if you Liked my post please mark it as helpful and accept it as an asnwer
  3. Shawn Gradwell
    Shawn Gradwell
    Guest
    I'm on version 14.00.0639.021, where do I find the RU's? Do I load 1 then 2 then 3 or just 3?
  4. busbar
    busbar
    Guest
    no load RU3 directly
    http://www.microsoft.com/downloads/details.aspx?familyid=7dcf2390-dff7-4e3a-acca-03f4d43fb79a
  5. Shawn Gradwell
    Shawn Gradwell
    Guest
    ....busy downloading, will install in exactly 6 hours and let you know. I appreciate your help!
  6. Shawn Gradwell
    Shawn Gradwell
    Guest
    OK, Setup RU3, Re-created the virtual directory. If I stop IIS then I get the normal error, when IIs runs I still get a blnk page. Any clues where I can start looking?
  7. Laeeq Qazi
    Laeeq Qazi
    Guest
  8. Shawn Gradwell
    Shawn Gradwell
    Guest
    Tried all things on the list and everything I can think of.. still blank page. Here's the page's source code:
    <!DOCTYPE HTML PUBLIC " -//W3C//DTD HTML 4.01 Transitional//EN" > <!-- Copyright (c) 2006 Microsoft Corporation. All rights reserved. --> <!-- OwaPage = ASP.auth_logon_aspx --> <!-- {57A118C6-2DA9-419d-BE9A-F92B0F9A418B} --> <html> <head> <link rel=" shortcut icon" href=" /owa/14.0.694.0/themes/base/favicon.ico" type=" image/x-icon" > <link type=" text/css" rel=" stylesheet" href=" /owa/14.0.694.0/themes/base/logon.css" > <link type=" text/css" rel=" stylesheet" href=" /owa/14.0.694.0/themes/base/owafont.css" > <script type=" text/javascript" src=" /owa/14.0.694.0/scripts/premium/flogon.js" ></script> <script type=" text/javascript" > <!-- var a_fRC = 0; var a_sUrl = " &url=https%3a%2f%2f172.16.0.114%2fowa%2f" ; var a_sCW = " https:\/\/172.16.0.114\/owa\/?ae=Dialog&t=CloseWindow&exsvurl=1" ; var a_sLgn = " logon.aspx?replaceCurrent=1" ; --> </script> </head> <body class=" owaLgnBdy" > <noscript> <div id=" dvErr" > <table cellpadding=" 0" cellspacing=" 0" > <tr> <td><img src=" /owa/14.0.694.0/themes/base/warn.png" ></td> <td style=" width:100%" >To use Outlook Web App, browser settings must allow scripts to run. For information about how to allow scripts, consult the Help for your browser. If your browser doesn't support scripts, you can download <a href=" http://www.microsoft.com/windows/ie/downloads/default.mspx" >Windows Internet Explorer</a> for access to Outlook Web App.</td> </tr> </table> </div> </noscript> </body> </html>
  9. S Kannan
    S Kannan
    Guest
    Hi Shawn,
    This issue may caused by failed installation of the RU3, therefore, I suggest you uninstall the RU3, then take some time to monitor to see if the issue will reoccur. If this issue will not reoccur, please reinstall the RU3.
    Rgds,
    Kannan
  10. Shawn Gradwell
    Shawn Gradwell
    Guest
    Kannan,
    Thanks for your help! So I will uninstall RU3, then see if the OWA website works? I will try that now, it did not work before RU3. Will uninstall quickly and check if it works, wil reply.
    Thanks again!
  11. Shawn Gradwell
    Shawn Gradwell
    Guest
    RU3 Uninstalled.. IIS resterted.. exactly the same problem. Should I run RU3 again?
  12. S Kannan
    S Kannan
    Guest
    Can you pls restart your Server and validate the OWA.
    Even after its not working. Kindly reinstall the roll update 3.
    Below reinstalling go through Description of Update Rollup 3 for Microsoft Exchange Server 2010 http://support.microsoft.com/kb/981401
  13. S Kannan
    S Kannan
    Guest
    Hi Shawn,
    Whether you have done any HTTP redirection in the exchange CAS server. if so
    Open the IIS go th the default website Re-HTTP options and check for redirect to the /owa & check the box the URL should match exactly same. similar go through all website under default website Re-HTTP option and uncheck he redirections
    http://technet.microsoft.com/en-us/library/aa998359.aspx
    With Rgds,
    S Kannan
  14. S Kannan
    S Kannan
    Guest
    What is the Status?
  15. Mikeymol
    Mikeymol
    Guest
    i am experiencing the exact same issues at a client. the strange this is, if i turn off FBA, I can logon fine. As soon as I turn on FBA, when I hit the site, I get a blank page. I have clicked on the error at the bottom of the screen, and get this:
    Webpage error details
    User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; InfoPath.3)
    Timestamp: Wed, 26 May 2010 12:24:19 UTC
    Message: Syntax error
    Line: 1
    Char: 1
    Code: 0
    URI: https://webmail.xxxxx.net/owa/14.0.694.0/scripts/premium/flogon.js
    There are no errors reported anywhere.
    I have installed rollup 3 successfully, and still this error.
    I have even copied the scripts folder from another 2010 server, with Rollup 3, and still no success.
    we are running on Server 2008 R2
    thanks
  16. Mikeymol
    Mikeymol
    Guest
    OK, so i have managed to fix the problem.
    We uninstalled update Rollup 3, restarted the server and did a re-install of Rollup 3. This still did not work.
    We un-installed Rollup 3 again, restarted and installed Rollup 2. Everything is working. I am going to leave it for a while before trying to upgrade to Rollup 3 again, or else wait for a rollup 4
    Mikey
  17. Shawn Gradwell
    Shawn Gradwell
    Guest
    Fixed, with some Application Log errors but working 100%.
    Uninstalled RU3, restarted server, Re-installed RU3. Fixed.
    I do get these two errors still in the Application Log:
    ============== 1 ===============
    Log Name: Application
    Source: Microsoft-Windows-IIS-W3SVC-WP
    Date: 6/2/2010 10:43:46 AM
    Event ID: 2268
    Task Category: None
    Level: Error
    Keywords: Classic
    User: N/A
    Computer: xxx.xxxxxx.local
    Description:
    Could not load all ISAPI filters for site 'DEFAULT WEB SITE'. Therefore site startup aborted.
    Event Xml:
    <Event xmlns=" http://schemas.microsoft.com/win/2004/08/events/event" >
    <System>
    <Provider Name=" Microsoft-Windows-IIS-W3SVC-WP" Guid=" {670080D9-742A-4187-8D16-41143D1290BD}" EventSourceName=" W3SVC-WP" />
    <EventID Qualifiers=" 49152" >2268</EventID>
    <Version>0</Version>
    <Level>2</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime=" 2010-06-02T08:43:46.000Z" />
    <EventRecordID>1020562</EventRecordID>
    <Correlation />
    <Execution ProcessID=" 0" ThreadID=" 0" />
    <Channel>Application</Channel>
    <Computer>xxx.xxxxxx.local</Computer>
    <Security />
    </System>
    <EventData>
    <Data Name=" SiteName" >DEFAULT WEB SITE</Data>
    <Binary>05000000</Binary>
    </EventData>
    </Event>
    ================ 2 =================
    Event ID: 2214
    Task Category: None
    Level: Error
    Keywords: Classic
    User: N/A
    Description:
    The HTTP Filter DLL C:\Program Files\Microsoft\Exchange Server\V14\ClientAccess\owa\auth\owaauth.dll failed to load. The data is the error.
    Event Xml:
    <System>
    <EventID Qualifiers=" 49152" >2214</EventID>
    <Level>2</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <EventRecordID>1020561</EventRecordID>
    <Correlation />
    <Security />
    </System>
    <EventData>
    <Data Name=" IsapiFilter" >C:\Program Files\Microsoft\Exchange Server\V14\ClientAccess\owa\auth\owaauth.dll</Data>
    </EventData>
    </Event>
Loading...
Share This Page
