CAS/HUB Roles not installing because they cannot connect to Domain Controller?
  • Thread starter Feldman
  • Start date Views 3,318
F
Feldman
Has anyone seen there issues while trying to install Exchange Server 2010 Enterprise?
Summary: 4 item(s). 1 succeeded, 3 failed.
Elapsed time: 00:00:40
Organization Prerequisites
Failed
Error:
The Active Directory needs to be prepared for Exchange Server and Ldifde.exe is not installed on this computer. You must install Ldifde.exe by running 'ServerManagerCmd -i RSAT-ADDS' or restart setup on a domain controller.
Error:
Setup encountered a problem while validating the state of Active Directory: An Active Directory error 0x51 occurred when trying to check the suitability of server 'AXEL.centralcatholic.private'. Error: 'Active directory response: The LDAP server is unavailable.'
Elapsed Time: 00:00:26
Languages Prerequisites
Completed
Elapsed Time: 00:00:02
Hub Transport Role Prerequisites
Failed
Error:
Warning:
This computer requires the 2007 Office System Converter: Microsoft Filter Pack. Please install the software from http://go.microsoft.com/fwlink/?LinkId=123380.
Elapsed Time: 00:00:06
Client Access Role Prerequisites
Failed
Error:
Unable to read data from the Metabase. Ensure that Microsoft Internet Information Services is installed.
Recommended Action: http://go.microsoft.com/fwlink/?linkid=30939&l=en&v=ExBPA.4&id=a4a4d339-4009-4fb7-b842-ca2ba79f13f0
Error:
Error:
Unable to access the 'Default Web Site' on this computer.
Recommended Action: http://go.microsoft.com/fwlink/?linkid=30939&l=en&v=ExBPA.4&id=aadc8176-1c47-49b7-83a0-9493a1093af1
Error:
The start mode for the Net.Tcp Port Sharing service must be set to Automatic before Setup can continue.
I am trying to understand what would cause the Domain Controller not to respond. Any Ideas?
TWHarrington
You are missing all the pre-reqs....Start with the Remote Administrator tools (RSAT) to get the Schema prepped. See link at bottom to get list of all pre-reqs
From powershell:
Import-Module ServerManager
Add-WindowsFeature RSAT-ADDS
Reboot server and try again.
(Or you can add them for the Features section of the Server Manager GUI)
See this link for all the pre-reqs: http://technet.microsoft.com/en-us/library/bb691354.aspx
Jonas Andersson [MCITP]
A little tip, all these prereq's can be easily installed by using:
servermanagercmd -ip z:\scripts\exchange-typical.xml
Z: is the cd/dvd , in the folder you will find exchange-*.xml files that could be used, it's really smooth
Jonas Andersson MCTS: Microsoft Exchange Server 2007/2010 | MCITP: EMA 2007/2010 | MCSE/MCSA Blog: http://www.testlabs.se/blog
F
Feldman
I have done what you both said but to no avail. I even check to make sure RSAT was installed and it was. Any other ideas?
TWHarrington
After all the pre-reqs were installed, you are still getting the same message in your error logs? Please post the new setup log.
Can you prep AD from a command line successfully?
Setup.com /PrepareLegacyExchangePermissions
Setup.com /PrepareSchema
Setup.com /PrepareAD
Setup.com /PrepareDomain
F
Feldman
All of what you mention passed successfully. Here is the new error log:
Elapsed time: 00:00:32
Failed
Error:
Elapsed Time: 00:00:20
Completed
Failed
Error:
Elapsed Time: 00:00:04
Failed
Error:
TWHarrington
Is windows firewall running on either server (exchange or DC)? Does exchange server have multiple nics?
Check you DNS settings, and verify it by using nslookup and pingJonas Andersson MCTS: Microsoft Exchange Server 2007/2010 | MCITP: EMA 2007/2010 | MCSE/MCSA Blog: http://www.testlabs.se/blog
Anil K Singh
Also i would recommend to run dcdiag and netdiag on server before shoot exchange 2010 installation. Its looking many problem from your DC side.Anil
F
Feldman
Looks like there is an issue here. The guy that worked here before I did have set up another trusted domain in the forest, but then just got rid of the Domain Controller. How can I remove a domain in the forest that is trusted by other domains?
ashganatra
Any luck with this i'm getting the same issue?ashish@kingsfieldcomputers.co.uk
