Queue Viewer mmc is not opening
  • Thread starter rajesh5631
  • Start date Views 500
rajesh5631
#1
Here the error message I'm getting:
MMC cannot open the file E:\Microsoft Exchange\bin\Exchange Queue Viewer.msc
This may be because the file does not exist, is not an MMC console, or was
created by a later version of MMC. This may also be because you do not have
sufficient access rights to the file
Mumin CICEK [MVP]
#2
hi,
check your permissions on it,
go to E:\Microsoft Exchange\bin\Exchange Queue Viewer.msc and right click properties and security tab. and then add your account.
try again to open Exchange Queue Viewer.msc
regards,
Mumin CICEK | Exchange - MVP | www.cozumpark.com | www.mumincicek.com
rajesh5631
#3
Hi Mumin ,
i have check permission but its ok..
but i got solutions and its working fine..
problem was that mmc file .i had removed that file after that working fine..
anyway..thanks
