1. Here's a thread that needs an answer: export free / busy from exchange
Calendar export to excel - problem
Discussion in 'Using Outlook' started by Michael T, Apr 25, 2009.
  1. Michael T
    Michael T
    Guest
    I am exporting my outlook calendar to excel and whilst with a very small
    date range it works ok, with anything over a few months (there will be a
    hundred or so per month not thousands) Outlook siezes 97% of the processer
    and the export dialog just sits there with one bar on the progress meter.
    I have tried the same with an Access export and even the smallest export
    siezes in the same way immediately.
    The export translater software was installed for both Excel and Access
    apparently successfully and the machine re-booted as well more than once.
    Has anyone any thoughts on why this might be?
  2. Diane Poremsky
    There may be a corrupt item, possibly with a recurring item. I'd move the
    recurring items to a new calendar folder then export the main folder and the
    recurring folder to see if it hangs. Once you see if either work, you'll
    have an idea where to look for problems.
    "Michael T" <michaelj@dsl.pipex.com> wrote in message
    news:VYSdnZgKEN8hcW_UnZ2dnUVZ8oSdnZ2d@pipex.net...
  3. TechGuy
    TechGuy
    Guest
    In case your still not happy with the export results, consider using a
    3rd party app called WinCalendar.
    It supports exporting Outlook Calendar as a fully formatted calendar
    into native MS Excel or MS Word format.
    It also supports 'Agenda' view & many calendar layouts.
    For more info see:
    http://www.wincalendar.com/Outlook-Calendar-Import.htm
    Enjoy
    Mike
Loading...
Share This Page
