error script when browsing Owa At exchange 2007
  • Thread starter Mohamed Hassan Mohamed
  • Start date Views 468
Michael Vi
What service pack level are you on for Exchange and OS?
What operating system, 2003 or 2008?
good day
Exchange 2007 sp1
windows server 2003 R2 standard X64 edition sp 2
G
Gavin-Zhang
Kindly suggest that you could check below:
Does the issue happen to only one user or all the user;
Does the the issue happen to the external user or internal user;
Does it a test scenario or a productive scenario;
Does the owa work well before or always has the issue after the deployment;
Does other feature all work well, please confirm those;
Can you open the owa site on the server;
And then, you could narrow down the issue, if it is the issue with the server end, you could:
1. run exbpa find some useful information, and post here we could give more suggestion for you
2. check the owa virtual directory check/uncheck the ssl to confirm whether is the CERT issue
3.normally about the script error you could recreate the virtual directory, you could refer to below link:
http://support.microsoft.com/kb/941201
If it is issue on client end, you could analyze the iis log on the server to find out the useful information.
Regards!
gavin
