Sync Issues
jpetre
Hello All,
This is my first post, we have an Exchange server 2007 we just upgraded from Exchange Server 2003. Upgrade went smoothly and no issues. So I let it run for a few months, well about 2 weeks ago I was following a document to remove / uninstall Exchange server 2003 from our network. Now I am getting sync error like the one below. I went on line and tried to find out what I could and came across several post to rebuild my address book.
Sync Error Below
9:58:29 Synchronizer Version 12.0.6509
9:58:29 Synchronizing Mailbox 'User'
9:58:29 Synchronizing Hierarchy
9:58:29 Synchronizing server changes in folder 'Inbox'
9:58:29 Downloading from server 'server.domain.com'
9:58:30 1 item(s) changed read-state in offline folder
9:58:30 Synchronizing server changes in folder 'Deleted Items'
9:58:29 Synchronizing Mailbox 'James Petre'
9:58:29 Downloading from server 'EVERGEMAIL1.evergegroup.com'
9:58:30 Downloading from server 'EVERGEMAIL1.evergegroup.com'
9:58:30 Done
9:58:30 Microsoft Exchange offline address book
9:58:30 0X8004010F
Error below when I tried to rebuild the Offline Address book, do you guys have any ideas what is going on? I tried a reboot last night but that didn't help. I really appriciate all your help! :)
Update-OfflineAddressBook : Failed to generate the content of the offline addre
ss book '\Default Offline Address List'. Two possible reasons for the failure a
re that the System Attendant Service is not running or you do not have permissi
on to perform this operation. Error message : 'Catastrophic failure (Exception
from HRESULT: 0x8000FFFF (E_UNEXPECTED))'.
At line:1 char:51
+ get-offlineaddressbook | update-offlineaddressbook <<<<
O
Office2Mobile
jpetre,
You may want to include what version of Outlook are you using. Remember that Exchange and Outlook 03 supported Free/Busy information through Public Folders. 07 supports Public Folders but does not create one by default, a prompt that you should have received during the install. You can also check to ensure that the OAB is replicating correctly.
Hope this helps,
Office2Mobile, On the move with enterprise-class tools hosted by http://themessagecenter.com/
