PROBLEM OF 'DISCONNECTED' IN OUTLOOK 2007 running XP PRO OS, IN A NETWORK OF WINDOWS SERVER 2003
V
vincen48
Please help, if you can.
I used to run a few Outlook 2007 with XP Pro OS in a Windows 2000 Server network and it was OK for years.
Last week, I upgraded the network to Windows 2003 server. After that, Outlook showed message "disconnected".
In order for Outlook to be connected, I had to take the server off the network, and it did get connected. After gettig the Outlook connencted, I put the server back, and it was OK. Nevertheless, it is now a pain because each time the Outlook is re-started, I have to teke the server out and put it back later.
I did try the following, but it did not work:
* checkinfg off the "Download shared Folder" in "Advanced" of "More Setting";
* Reg edit and creating the RCP entry, etc.
Please help with you know the solution.
Thank you very much.
Vincen48
vincen@newtonlawgroup.net
E
Ed Crowley [MVP]
What version of Exchange?
Ed Crowley MVP
"There are seldom good technological solutions to behavioral problems."
"vincen48" wrote in message news:13a5d9b7-7cb1-4261-b9ec-fd446dbc1259...
Vincen48
Ed Crowley MVP "There are seldom good technological solutions to behavioral problems."
E
Elvis Wei
Hi Vincen48,
Are you using Exchange? What"s the meaning of “I had to take the server off the network,”? How you Outlook connect to your mail server? Pop3/imap4 or Exchange mode?
Elvis
