Data Loss
  • Thread starter carlogoffi
  • Start date Views 619
C
carlogoffi
I went to use my outlook last week and all of my data was gone. I have tried searching for .pst files and although I fiound a very old one I was unable to find my current data. I have current data on my pda which was synched just before the loss but i am unable to reverse synch and populate my outlook.
Help!
H
Hal Hostetler - Print-Imaging [MVP]
What type of email accout do you use? Go to 'Control panel|Mail' and open your profile. Click on Data files to check the pst location, then go to that location and verify it is still there.
Hal
Somasundaram Pandiaraj
Which mobile device do you use to sync with outlook?
Make a backup of the data on your phone and then try the following steps.
1) Delete the existing partnership
2) Create a new profile in outlook
3) Recreate the partnership and then try to sync.
