Need help with multiple 'clickable' icons in Outlook signature for 2003 and 2007
mike8712
We have some staff with 2003 and some with 2007 and I'm having issues with trying to get our nice signature in place. It has some clickable icons embedded and is a small, clean file and works great in other e-mail applications but Outlook will not support the separate links. So, I can create one .png file with image and links and while this works for other apps, it won't work in Outlook. It only shows the image and allows for 1 link to be placed over the entire image itself, which does not help.
Is this just a limitation within Outlook or are there any tricks that would allow multiple small icons inside a signature image that will click through as designed? Thank you for your help - I've tried several things and would love some fresh ideas if they are out there.
mike
