Outlook 2010 will not reopen after closing it.
  • Thread starter kmcatee
  • Start date Views 1,770
K
kmcatee
Recently upgraded from Office 2007 to Office 2010. Outlook 2010 loading screen will show " Loading Profile" for a very long time if it is closed and reopened. The only way to get it to open again is to restart the PC. This is very annoying if I accidently close Outlook.
Sachin Shetty
Try opening Outlook in safe mode and check what happens
1. Click on start>all programs>accessories>run
2. Type “Outlook /safe”(without quotes)
Note: there is a space between Outlook and “/”
3. If opening Outlook in safe mode works try disabling the add-ins and check
4. To disable add-ins
a. Open Outlook
b. Click on File>Options>Add-ins
c. Com add-ins>Go
d. Uncheck add-ins one at a time and check which one is causing the issue
5. If the above steps fail create a new profile and check if it works.
http://support.microsoft.com/kb/829918
K
kmcatee
The problem isn't with add-ins. I found another article that helped. It said to delete the profiles key:
Go to Start > Regedit
Locate HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows Messaging Subsystem
Delete the Profiles key under the Windows Messaging (Subsystem) key.
