outlook pro 2010 Indexing email problem
BORABORA2
Each time I start Outlook, It seem that the index is rebuilding itself from scratch even if it was completed successfully previously. Therefore, I must wait like over an hours to be able to use the search function in outlook everytime I start it which is very frustrating...
I am using windows 7 home premium x64 with outlook pro plus V.14.0.4760.1000 64-bit
E
Ezil Vinoth
Does this happen only during Outlook search or even in windows search?
Try re-building the index directly from the indexing options and check if it helps. To do this
1. Click Start> Control panel> Indexing options> Choose the advanced options
2. Click on re-build
If the above fails, check in new profile for Outlook.
BORABORA2
I already use the re-build option but again today outlook restart the indexing from scratch ?
This happen during outlook search only. I dont have any problem with windows search.
Stephan G.
E
Ezil Vinoth
Did you create a new Outlook profile to verify the status?
If yes what was the outcome?
If a POP account is in use, what is the size for the PST file?
To reconnect the old PST to the new profile, try the following steps:
1. Open Outlook using the new profile, click on File > Open > Open Outlook Data File
2. Select the target PST to open and set it as default
