mstalcott
Having difficulty with getting the IRM perms correct, apparently:
RMS on Server 2008R2, Exchange2010, EXCHServers group has Read/Execute perms on servercertification.asmx and the inheritable checkbox is set.
[PS] C:\Program Files\Microsoft\Exchange Server\V14\Scripts>Set-IRMConfiguration -InternalLicensingEnabled $true
No connection could be made because the target machine actively refused it 192.168.1.46:443 ---> Unable to connect to t
he remote server ---> Failed to get Server Info from https://rms.baupost.com/_wmcs/certification/server.asmx.
+ CategoryInfo : InvalidOperation:
) [Set-IRMConfiguration], Exception
+ FullyQualifiedErrorId : 8E3210B2,Microsoft.Exchange.Management.RightsManagement.SetIRMConfiguration
[PS] C:\Program Files\Microsoft\Exchange Server\V14\Scripts>Test-IRMConfiguration
cmdlet Test-IRMConfiguration at command pipeline position 1
Supply values for the following parameters:
Sender: ************
Results : Checking Exchange Server ...
- Exchange Server is running in Enterprise.
Loading IRM configuration ...
- IRM configuration loaded successfully.
Retrieving RMS Certification Uri ...
- RMS Certification Uri: https://rms.baupost.com/_wmcs/certification.
Verifying RMS version for https://rms.baupost.com/_wmcs/certification ...
- Warning! Failed to verify RMS Version. IRM features require AD RMS on Windows Server 2008 SP2 with the
Hotfixes specified in Knowledge Base article 973247 (http://support.microsoft.com/kb/973247) or RMS on Window
s Server 2008 R2.
-------- Microsoft.Exchange.Security.RightsManagement.RightsManagementException: Failed to get Server Info from https:
//rms.baupost.com/_wmcs/certification/server.asmx. ---> System.Net.WebException: Unable to connect to the rem
ote server ---> System.Net.Sockets.SocketException: No connection could be made because the target machine ac
at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& soc
ket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Int32 timeout, Exception& except
ion)
--- End of inner exception stack trace -
at System.Net.HttpWebRequest.GetRequestStream(TransportContext& context)
at System.Net.HttpWebRequest.GetRequestStream()
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
at Microsoft.Exchange.Security.RightsManagement.SOAP.Server.ServerWS.GetServerInfo(ServerInfoRequest[] req
uests)
at Microsoft.Exchange.Security.RightsManagement.ServerWSManager.ValidateServiceVersion(String featureXPath
at Microsoft.Exchange.Management.RightsManagement.IRMConfigurationValidator.ValidateRmsVersion(Uri uri, Se
rviceType serviceType)
at Microsoft.Exchange.Management.RightsManagement.IRMConfigurationValidator.TryGetRacAndClc()
s Server 2008 R2.
ion)
uests)
