Having trouble importing PSTs into Exchange 2010 SP1
F
Finchy72
I'm trying to import bunch of PSTs into Exchange 2010 using PowerShell and i'm a bit lost, can someone help me with any articles or tips of what I need to look out for/ ensure I have running?
[MT]
Here is the official resource from technet for exchange
http://technet.microsoft.com/en-us/library/ee633455.aspx
http://www.msexchange.org/articles_tutorials/exchange-server-2010/management-administration/exporting-importing-mailboxes-exchange-server-2010.html
http://www.msexchange.org/articles_tutorials/exchange-server-2010/management-administration/import-export-mailboxes.html
Make sure
Office Outlook 2010 Installed
Exchange Server 2010 management tools Installed
Import export roles permission Configured
MT | MCITP ----- Please vote helpful or mark as answer if it's answered your question, this help us follow up the question status.
F
Finchy72
So I"d created a PST at the location c:\pstfiles\user.pst to test importing PSTs into Exchange 2010 via PowerShell.
I"d already installed 64bit outlook on the server, and added import export roles to the account I was using.
I was then using the command "Import-Mailbox –Identity [Username] –PSTFolderPath
c:\pstfiles\user.pst" to import this pst file into [username]"s mailbox.
And hit the following error:
Error was found for XXX because: Error occurred in the step: Approving object. An unknown error has occurred., error code: -2147221219 + CategoryInfo : InvalidOperation: (0:Int32) [Import-Mailbox], RecipientTaskException + FullyQualifiedErrorId : CFFD629B,Microsoft.Exchange.Management.RecipientTasks.ImportMailbox
I'm struggling to find information on what this means
[MT]
Hi Mike,
Glad that you take note on the SP1 mentioned on the subject. (I overlooked this).
Just to check with you, if the error code: -2147221219 appears on the server. The server was not patched to SP1 yet, we have applied work around as mentioned by korneel, am i right?
http://www.korneel.nl/?p=28
F
Finchy72
Thanks very much for your help MT and Mike, I had to postpone the project for a few weeks (I really didn't expect it to be so tricky! - I am a Powershell novice :)) but I am now back on it. The articles you suggested don't help with errors (I'm guessing I've missed something with my setup that would mean the scripts would just run). After a bit more digging, I found this site that went over much the same process as the ones you have suggested but included some of the errors I encountered: http://sysadmin-talk.org/2010/08/how-to-import-pst-files-into-exchange-2010-the-manual-way/.
