Re: 2010 SP1 installation error
E
egelandc
I've found a work around. Seems like there something wrong with installation causing the services to go to disabled mode. I've just changed the service state to automatic for all the exchange-services, started the one msexchangeservicehost, with the required other services.
It' successfully installed the Client access update.
Christian
tvandael
Already tried this, but when the "restoring services" step is executed, all is back to disabled.
Or did you change it after the "restoring services" step?
Greetz
Tim
E
egelandc
Changed it after, while it changed it to disabled. It does this a couple of times, probably something bigger causing this to happen :). But I'm running in a test lab, so it doesn't matter. Just look in services, while the setup is running. And change it back to automatic, start the services if it's not running.
Christian
tvandael
I've got it installed.
Open the services.msc and check the exchange services.
At every step they are being disabled.
When they are disabled run the following script in a powershell window: get-service msexch* | set-service -startuptype automatic
Keep repeating this with every step of the installation.
A reboot and every thing works.
Hope it helps you guys...
Greetz
Tim
