Outlook 2003 sp3 - problems display messages content
Jeffreyhk
Dear Sir,
When I recevie a email from Outlook 2003 sp3, the message content is missing few lines.
However, When I recevie a same message from Outlook Express, the message content is correct.
I attached a email message header for your reference:
Message Header:
Received: xxxxxxxxxxxxxxxxxxx([193.38.xxxx])
by xxxxxxxxxxxxx(Merak 8.3.8) with ESMTP id JEH65921
for <xxxxxxxxxxxxxxxx>; Thu, 2 Sep 2010 05:32:21 +0800
X-TM-IMSS-Message-ID:<xxxxxxxxxxxxxxxxxx>
Received: from xxxxxxxx.na.blackberry.com ([xxxxxxxxx]) by xxxxxxxxxxx([xxxxxxxxxxxx]) with ESMTP (TREND IMSS SMTP Service 7.0) id 0a59e2ea00057ee7 for <xxxxxxxxxxxxx=ramya@srs.bis.na.blackberry.com>; Thu, 2 Sep 2010 05:19:15 +0800
Received: from bda612.bisx.prod.on.blackberry (bda612.bisx.prod.on.blackberry [172.20.218.157])
by srs.bis.na.blackberry.com (8.13.7 TEAMON/8.13.7) with ESMTP id o81LVqkj006334
for xxxxxxxxxxx; Wed, 1 Sep 2010 21:33:39 GMT
X-rim-org-msg-ref-id: 390253304
Message-ID: <xxxxxxxxx_blackberry.rim.net-120918264-@bda612.bisx.prod.on.blackberry>
Reply-To: xxxxxx
X-Priority: Normal
Sensitivity: Normal
Importance: Normal
Subject: Fw: xxxxxxx help?
To: xxxxxx
Date: Wed, 1 Sep 2010 21:33:39 +0000
Content-Type: multipart/mixed; boundary=" part30234-boundary-1940213059-1502906494"
MIME-Version: 1.0
X-TM-AS-Product-Ver: IMSS-7.0.0.6126-6.5.0.1024-17610.002
X-TM-AS-Result: No--85.532-3.0-31-1
X-imss-scan-details: No--85.532-3.0-31-1;No--85.532-5.0-31-1
X-TM-AS-User-Approved-Sender: No;No
X-TM-AS-User-Blocked-Sender: No;No
Regards,
Jeffrey
Jeffreyhk
--part30234-boundary-1940213059-1502906494
Content-Transfer-Encoding: base64
Content-Type: text/plain; charset=" Windows-1252"
Content-type: application/ms-tnef; name=" winmail.dat"
Content-transfer-encoding: base64
Content-disposition: attachment; filename=" winmail.dat"
Any releated ?
V
Vinay - G
Open outlook in safe mode and check if it helps:-
Hold CTRL key and click on the outlook icon and choose to open in safe mode.
Check if &ldquo;Read all standard mail in plain text&rdquo; option in Outlook 2003is turned on. You need to uncheck this option which will not show HTML contents:-
1. Start Outlook 2003.
2. On the Tools menu, click Options.
3. On the Preferences tab, in the E-mail area, click E-mail Options.
4. In the Message handling area, check if &ldquo;Read all standard mail in plain text&rdquo; box is checked.
5. Uncheck if it is checked and see if you are able to see the message content.
