1. Here's a thread that needs an answer: Filter and Save Contacts to a CSV File
forward button in Outlook 2010 toolbar is greyed out and does not work
Discussion in 'Using Outlook' started by Bruce 99, Sep 6, 2010.
  1. Bruce 99
    Bruce 99
    Guest
    Issue only affects the toolbar button. I can forward by right clicking on the e-mail, or contol f, or by using the ribbon command. All other commands in the toolbar work fine.
  2. Milly Staples - MVP Outlook
    Guest
    By toolbar, do you mean the Quick Access Toolbar? If yes, remove the command and add it back via the customization option on the QAT.
    " Bruce 99" wrote in message news:7b594d3d-d4c0-437f-a7e0-ada4783285b5@communitybridge.codeplex.com...
  3. Bruce 99
    Bruce 99
    Guest
    Thanks for you help. Removing the button and replacing it from the QAT did not fix the problem. But using the add to QAT option from the ribbon did fix the problem.
Loading...
Share This Page
