after installation I have no contacts.
julie hendrix
where can i find my contacts or previous emails, all history is gone.
V
Vinay - G
If you used earlier version of outlook and configured with pop3 account then you can still look for your PST file and open in outlook 2010:-
1. Click on file->open->open outlook data file
Navigate to C:/Documents and settings/User name/Application data/Microsoft/outlook.
2. Click on the PST files present in the folder and click open.
3. When you get the PST file that contains all the data you can set it as default under file->data management.
Your Personal folder file will contain all your emails and contacts.
If you used a IMAP or outlook connector account then simply reconfigure the account which should sync to your server and download all your emails and contacts.
