1. Here's a thread that needs an answer: Prevent Users From Choosing Stationery
Reminders don't pop up and stay hidden in background
Discussion in 'Using Outlook' started by StefanW, Sep 14, 2010.
  1. StefanW
    StefanW
    I'm at a new workplace with a new PC with Windows 7 and Office 2010 and get into trouble regularily, since meeting reminders simply stay hidden behind all my open documents and never make it to the top to remind me. In older versions they popped up on top, you could hit snooze and they would pop up again until you hit dismiss.
    The new menu structure is really hard to navigate and not as easy as in 2003. I found the options menu but there is no check box to force reminders to really pop up. I see this as a serious bug.
  2. Diane Poremsky
    Yeah, reminders are a big problem. The problem is partly with windows 7 - it doesn't let programs come up on top. There isn't a prefect solution - i'm using reminder manager at slovaktech.com which helps. (it can also send reminders by email).
  3. Phil Seeman
    Phil Seeman
    If you want to see your reminders as alerts that appear just above the Windows system tray, I've written a little utility to address this issue - Reminder Alerts. A free beta version is available at http://www.moreproductivenow.com/reminder_alerts.htm. Currently supports Outlook 2007 and 2010.
  4. Darth Andy
    Darth Andy
    I posted this before, but no-one appears to have noticed ;-)
    You can use VB to give you an on-top pop-up:
    Code (Text):
    Copy Source
       If TypeOf Item Is AppointmentItem Then
       MsgBox "There's a reminder! Click OK to see it", vbSystemModal, "Dude!"
    You need to put this under 'ThisOutlookSession' and sign it with a digital certificate (plenty of info elsewhere on how to do that)
    I admit it's not an elegant solution, but if you need something to be all up in you face about meetings, then this will do it.
    Madheshwaran and Francis like this.
  5. Diane Poremsky
    Will test this macro - i like that it works only for appointment reminders - flag reminders are less important and for those items i flag instead of creating appointments, i'll just have to create appointments now.
  6. vcadambe
    vcadambe
    We developed ShowReminders, an addin for Outlook 2010/2013, that brings the Outlook reminder to the forefront without taking focus away from any application that you are working on. It is available for download at www.sagelamp.com/pages/showreminders.aspx. Please check it out and I would love to hear your feedback.
  7. Francis
    Francis
    @Darth Andy: Your solution works , but I no longer get the letter icon on top of Outlook to show I have mail.
    (I'm in Outlook 2013 64bits)
  8. Madheshwaran
    Madheshwaran
    Great, thanks for this simple solution, it served the purpose.
Loading...
Share This Page
