1. Here's a thread that needs an answer: ReplyAll
offline button is greyed out
Discussion in 'Using Outlook' started by Stefano58, Sep 30, 2010.
  1. Stefano58
    Stefano58
    Guest
    I have several clients in which the offline button is greyed although " cached mode" is selected in our exchange/client config. Any ideas why? button should be available to the users in order for them to work offline etc.
  2. Ben M. Schorr [MVP]
    Ben M. Schorr [MVP]
    Guest
    It's greyed out in the Ribbon? Are you sure you're in Cached mode? Look at the bottom right on the status bar does it say " All Folders are Up to Date" or " Updating" and " Connected to Microsoft Exchange" or does it say " Online with Microsoft Exchange Server" ?
  3. Stefano58
    Stefano58
    Guest
    Hi, yes in the outlook email config cached is checked.
  4. Ben M. Schorr [MVP]
    Ben M. Schorr [MVP]
    Guest
    Yes, I see that you have cached mode checked in the Config. What I'm trying to confirm is that your Outlook is actually IN cached mode - i.e. that cached mode is working properly.
    Have you tried creating a new Outlook profile? Troubleshooting Outlook -http://www.officeforlawyers.com/outlook/tsol.htm#newprof
Loading...
Share This Page
