I have 5 emails stuck in the outbox that are probably too large to be sent, but I can not delete them. How do I delete them and start over sending th
  • Thread starter ode2golf
  • Start date Views 616
O
ode2golf
I have five emails stuck in the outbox. How do I delete them and start over?
O
ode2golf
Ruchi Bisht
Try the following steps:
1. Open Outlook
2. Click on File > Work Offline
3. Click on the Outbox folder and delete the e-mails
4. Repeat the step 1 to 2 to disable Work Offline
There are several ways to reduce the size of an email however this will depend on the type to content used in the email.
For example, if you are sending files as attachments from Outlook then you may compress those files using Right-Click > Send To > Compressed (zipped) folder
For pictures, you may use Picture Manager to reduce the pixel.
Ruchi Bisht
