Outlook categories for draft messages?
E
EtherKnight
Though the 'category' button exists on the inbox and sent folders, I cannot find a way to all the button to newly created message I have yet to send. When I use 'customize the ribbon' on a draft message that option is not there. Currently it is taking 4 clicks to set a category on a new message: Tags > Categories > (my category) > Close.
There does not seem to be a way to add a Category button to the Ribbon. There are a gajllion other options, but that one is not available for some reason.
I have a 'defer sending' rule in place and I use categories to mark certain messages as exceptions to that rule (i.e. they get sent immediately). I could go to the Outbox and use a quick click to set it there, but it won't send unless I open the messages and click send again (usually I have to do this twice before it will send).
Am I missing a check box somewhere? I tried this add-in to provide this function (VBOffice 'Category Manager'), but it's just a window that gets in the way of other things. If I could get a native Ribbon button, that would great. At this point, even a macro would be cool...seems like a pretty basic feature that is inexplicably missing.
H
Harry Yuan
I would like to give the advice to you is delete all the categories then re-create categories.
The easiest way to delete use the following commend .
Start menu–> RUN—> and enter “c:\program files\microsoft office\office12\outlook.exe” /cleancategories“
Specifically how to re-create use the article link:
Create and assign color categories
http://office.microsoft.com/en-us/outlook-help/create-and-assign-color-categories-HA010217901.aspx
Regards,
Harry Yuan
BBCTX
I too am having the same issue. Harry Yuan from MSFT obviously didn't read your email because it has absolutely nothing to do with what you want to do.
I tried assigning a keyboard shortcut to a category and it will not flag it while the email is a draft.
It will only categorize it once the email is in the sent items folder. This is frustrating to me as well. If you find a solution, please be sure to come back and post it. I will do the same.
Thanks, BBC
