outlook 2010 will not attach contacts to address book
  • Thread starter jpate
  • Start date Views 506
jpate
I tranfered files from an xp box and the address book will not work properly. someone suggested creating a new address book to repair the link. this did not work and even with a second address book, i can't delete the outlook address book. Any suggestions?
H
Hassan El-Meligy, MSc
exit outlook goto control panel -> Mail select either data files or email accounts goto the Address Book tab try to remove the files from there that you do not need create or organize your data and address book from withing old or new profilesrestart outlook and understand this process, you will be able to solve your other problem from there as welllocate also other issues such as default address book
Regards
