Problem exporting Exchange 2010 selsigned certificate
Remco Tiel
Due to a migration project from Groupwise to Exchange (Exchange 2010 SP1) I'm using temporarily a self signed certificate for Exchange. I want this certificate to deploy via GPO and am running into the following problem. I'm using the following code to export the certificate to a file:
$file = Export-ExchangeCertificate -Thumbprint 89F6B890FD76EFAFC1E359001AFDD51D99F8BFC8 -Password (Get-Credential).password
Set-Content -Path "c:\certificates\htcert.pfx" -Value $file.filedata -Encoding byte
But when running this command I'm getting the following error message:
The private key couldn't be exported as PKCS-12. It either couldn't be accessed or isn't exportable.
+ CategoryInfo : InvalidArgument: :)) [Export-ExchangeCertificate], InvalidOperationException
+ FullyQualifiedErrorId : 77B0CDDB,Microsoft.Exchange.Management.SystemConfigurationTasks.ExportExchangeCertificate
How can I fix this?
Raffaele Colavecchi
if you are sure that you run this command with Admistrative Privilege elevation, your selfsigned certificate have private key not exportable.
Other try it's to export your certificate with MMC - Certificates (Local computer). If you cannot export with mmc your solution it's to recreate a certificate with the exportable private key.
You can use this comlet: New-ExchangeCertificate with option: PrivateKeyExportable
DANGER: By default, all certificate requests and certificates created by this cmdlet don't allow the private key to be exported.
At the end you must redeploy the public key with GPO in all other Domain clients and servers.
bye bye.
Raffa!
Remco Tiel
Is it possible to renew the certificate by the following command so the private key is exportable?:
Get-ExchangeCertificate -Thumbprint 89F6B890FD76EFAFC1E359001AFDD51D99F8BFC8 | New-ExchangeCertificate -PrivateKeyExportable $true
Remco
Santhosh Sivaraman
Remco
Dear Remco,
Yes, you can try this command.
Santhosh
Santhosh Sivaraman MCITP: Microsoft Exchange Server 2007/2010 | MCSE/MCSA
