Hotmail Connector Problem - "The Network Connection has been interrupted"
  • Thread starter Todd Oberman
  • Start date Views 2,350
Todd Oberman
I use 5 different Hotmail & Live based mailboxes with Outlook 2010 64-bit. The Hotmail Connector 64-bit has worked perfectly up until today. I recently upgraded it when asked. Today I am consistently getting the following error with all of those accounts:
Task '###' reported error (0x8004100B): 'The network connection was interrupted. Please try again later.'
Yesterday I installed the patches pushed this month by Microsoft for Windows, Office and Security Essientials client. I suspect there is an interaction with one of those patches.
In attempting to fix this, I have run the Hotmail Connector 64-bit installation and tried the " Repair." Did not fix problem. I have uninstalled and re-installed the Hotmail Connector. Did not fix the problem.
Is anyone else seeing this problem? A search of the net shows others have seen this problem before, but I am yet to find anything guiding to a resolution.
Todd Oberman
A reboot at the end of the day has made the original error go away. Hotmail appears to be synching, but there are some odd error messages too: " Error with Send/Receive" and " Please make sure your account is configured correctly by first accessing you account on the web. Error: 4203"
Mail is arriving from all my accounts. This error is only with one of the accounts.
Oddness.
Todd Oberman
Natasha and Niranjan,
This KB is not the answer to Error 4203; the resolution suggested does not fix the problem. I removed all entries on both Hotmail on the web and in Outlook for safe and blocked senders. Having been on Hotmail since the '90's there were quite a few old uneeded ones. Error 4203 still occurs in every synchronization. I am just living with this problem as it does not block my e-mail usage. It's noise I wish were not there.
If you have to mark this for your metrics, just mark this one as abandoned, unless someone can come up with a real answer to remove error 4203.
Todd
