Send and receive errors when synching with Hotmail
scoates904
I have been using Outlook flawlessly until just recnetly the inbox/outbox will not synch with Hotmail. The account is not available. I am signed into MSFT Live, and even tried to add the account again...still nothing
Here is the error message
Task 'Sending' reported error (0x80040126) : 'The operation cannot be performed because the connection to the server is offline.'
G
Ganesh Kumar N
Which version of Outlook Connector do you use?
Try the following:
1. Open Control Panel -> Programs and Features and remove Outlook Connector 12.1/ 14
2. Remove the Hotmail account(s) from Outlook
3. Click on Start > All programs > Accessories > Run > copy and paste the following text in Open field and then press Enter: %userprofile%\Local Settings\Application Data\Microsoft\Outlook
Remove the OST files for the Hotmail account from the above location
5. Install theOutlook Connector 14.1 and add the Hotmail account using Hotmail Connector
Ganesh Kumar N
scoates904
Ganesh,
Thanks for the guidance, but I after completing the above steps I am still receiving the following error:
Task 'myemail@msn.com' reported error (0x80004005) : 'Network operation failed'
Task 'myemail@msn.com' reported error (0x8004102A) : 'Error with Send/Receive. There was an error synchronizing your folder hierarchy. Error : 80041004.'
Naturally, I am able to send and receive email though Hot Mail, so network connectivity is not the issue. What other ideas do you have?
